- 36
- 2002-11-24
发表于 2003-10-8 20:50:53
来自 江苏南京
回复: 【讨论】应变率的输出问题
Subject: Re: Abaqus post-rpocessing issue
Hi
The subroutine UVARM can be used to define a user defined post-
processing variable, however I do not have a fortran compiler on my
m/c.
For the product of strain and strain rate, why not create a field
varaiable in abaqus cae defined as:
E*ER (small strains)
LE*ER (large strains)
For example, to create a field variable for step 1 increment 7 the
expression should be of the form:
s1f7_LE*s1f7_ER
The tensor multiplication is recognised automatically. My problem
concerned incorporating user defined data which is a function of a
field variable.
Regards
Barry
--- In ABAQUS@yahoogroups.com, Timmy Horgan <Timothy.Horgan@u...>
wrote:
> Hi,
> I would actually love to know how to add a user defined variable
too. Essentially I would like to see fringe plots of a variable which
is the product of strain and strain rate.
> If you have any luck finding that subroutine I would like to see it
if it was ok?
> Many Thanks,
> Tim.
> ----- Original Message -----
> From: Steve Manifold
> To: ABAQUS@yahoogroups.com
> Sent: Thursday, September 25, 2003 1:23 PM
> Subject: Re: [ABAQUS] Abaqus post-rpocessing issue
> There is a way to create a user defined variable using a user
subroutine. The user defined variable can be plotted in contour
plots. I did it a while back, I'll have to dig around and see if I
can find how I did it.
> From: barryodonnell2003
> Sent: Wednesday, September 24, 2003 7:06 AM
> Subject: [ABAQUS] Abaqus post-rpocessing issue
> Hi
> I wish to create field output based on the following type
expression:
> reserve = von_mises_stress / UTS(temp)
> The von mises stress and temperature are existing field
variables for
> a single increment (note: both vary spatially throughout the
model).
> The UTS is a known graph of UTS verses temperature which can be
> inputted as an ascii file. The main problem is, how can I
create the
> field output (i.e. reserve) for subsequent contouring.
> This is a point and click operation in our in-house FEA code.
> Barry
> ODCS Ltd.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> Community email addresses:
> Post message: ABAQUS@yahoogroups.com
> Subscribe: ABAQUS-subscribe@yahoogroups.com
> Unsubscribe: ABAQUS-unsubscribe@yahoogroups.com
> List owner: ABAQUS-owner@yahoogroups.com
> Shortcut URL to this page:
> http://groups.yahoo.com/group/abaqus
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> [Non-text portions of this message have been removed]
> ADVERTISEMENT
Service.
> [Non-text portions of this message have been removed] |
