查看: 112|回复: 1
[后处理] 数据传递发生系统错误,代码为529697949。
发表于 2016-6-25 13:32:56 | 显示全部楼层 |阅读模式 来自 陕西西安
在数据传递的过程中总是出现错误。已经将mkl_avx2.dll文件名改成mkl_avx2.13.0.0.1.dll。仍然报错The executable pre.exe aborted with system error code 529697949. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
发表于 2018-4-12 08:28:38 | 显示全部楼层 来自 中国
遇到同样的问题,楼主问题解决没?求指教
GMT+8, 2024-4-17 04:54 , Processed in 0.028264 second(s), 11 queries , Gzip On, MemCache On.
