- 2014-3-23
我做的是静态的轮轨接触分析,但是计算完成之后发现接触斑有问题,下图是接触斑的图片,inp也给出来了,请各位大神帮忙分析分析。
** INTERACTIONS
** Interaction: Int-1
*Contact Pair, interaction=IntProp-LG5, type=SURFACE TO SURFACE, adjust=0.0001
Surf-RAIL-2, Surf-LD-2
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES, inc=100000
*Static
0.01, 1., 1e-08, 1.
** LOADS
** Name: Load-g Type: Gravity
*Dload
, GRAV, 9.8, 0., -1., 0.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field
*Node Output
CF, RF, RT, U
*Element Output, directions=YES
LE, PE, PEEQ, PEMAG, S
*Contact Output
CDISP, CFORCE, CNAREA, CSTRESS, CSTRESSETOS
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
