- 2016-8-12
发表于 2016-9-8 23:42:15
来自 江苏
这是什么原因,求解答
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 1970374: Unknown assembly node set ALLNODES
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 1970380: Unknown assembly element set ALLELEMENTS
Error in job Job-1: AN INITIAL CONDITION HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_ALLNODES. THIS NODE SET IS NOT ACTIVE IN THE MODEL
Error in job Job-1: AN INITIAL CONDITION HAS BEEN SPECIFIED ON ELEMENT SET ASSEMBLY_ALLELEMENTS - THIS ELEMENT SET IS NOT ACTIVE IN THE MODEL
Error in job Job-1: 965820 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection.
Error in job Job-1: ELEMENT SET _Whole_Model_Gravity_Elset HAS NOT BEEN DEFINED
Job Job-1: Analysis Input File Processor aborted due to errors.
Error in job Job-1: Analysis Input File Processor exited with an error.
Job Job-1 aborted due to errors. |
