- 12
- 2009-10-25
rt
*SOLID SECTION, ELSET=Reservoir tube, MATERIAL=Elastic_steel
*SOLID SECTION, ELSET=Cylinder tube, MATERIAL=Elastic_steel
*SOLID SECTION, ELSET=Oil_Seal, MATERIAL=Elastic_steel
*SOLID SECTION, ELSET=Base_Cup, MATERIAL=Elastic_steel
*SOLID SECTION, ELSET=Rod_Guide, MATERIAL=Elastic_steel
*SOLID SECTION, ELSET=Base_Valve, MATERIAL=Elastic_steel
*RIGID BODY, REF NODE = 190003, ELSET = Rod_Guide
*RIGID BODY, REF NODE = 190002, ELSET = Base_Valve
if not,error will arise like below,why?
"Error in job 22271376_HM: ELEMENT SET BASE_VALVE REQUIRES A *SOLID SECTION PROPERTY DEFINITION IN ADDITION TO THE *RIGID BODY PROPERTY DEFINITION"
Many thanks!
