- 2017-3-21
发表于 2017-3-21 14:00:34
来自 华中科技大学韵苑公寓
楼主,俺安装了,但是出现
出现以下错误 The executable standard.exe aborted with system error code 1073741795. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.这个怎么破 |
