查看: 56|回复: 0
[ANSYS/LS-DYNA] ls-dyna总是自动退出是什么原因
发表于 2017-3-16 08:47:52 | 显示全部楼层 |阅读模式 来自 北京
   请问,ls-dyna计算到一半儿的时候就不再计算了,是什么原因呢?
  Date: 03/15/2017      Time: 13:30:55
     ___________________________________________________
     |  Livermore  Software  Technology  Corporation   |
     |  7374 Las Positas Road                          |
     |  Livermore, CA 94551                            |
     |  Tel: (925) 449-2500  Fax: (925) 449-2507       |
     |  www.lstc.com                                   |
     |_________________________________________________|
     |  LS-DYNA, A Program for Nonlinear Dynamic       |
     |  Analysis of Structures in Three Dimensions     |
     |  Version : ls971s R5.1.1   Date: 03/23/2011     |
     |  Revision: 65543           Time: 12:57:02       |
     |  Features enabled in this version:              |
     |    Shared Memory Parallel                       |
     |    Interactive Graphics                         |
     |    ANSYS Database format                        |
     |              nse (ANSYS140)                     |
     |  Licensed to:                                   |
     |  Platform   : WINDOWS X64                       |
     |  OS Level   : Windows XP/Vista/7 SRV 2003/2008  |
     |  Compiler   : Intel Fortran 10.1 & MSVC++ 2008  |
     |  Hostname   : dell-PC                           |
     |  Precision  : Single precision (I4R4)           |
     |  SVN Version: 65578                             |
     |  Unauthorized use infringes LSTC copyrights     |
Input file: e:\r-xm\geely\xingca~1\201702~1\20170313\201703~1.k
The native file format       : 32-bit small endian
Memory size from default     :    20000000
expanding   memory to    20000000 starting ls-dyna
********  notice  ********  notice  ********  notice  ********
* This is the LS-DYNA Finite Element code.                   *
* the validity, accuracy, or applicability of any results    *
* obtained from this system. The user must verify his own    *
* results.                                                   *
* LSTC endeavors to make the LS-DYNA code as complete,       *
* accurate and easy to use as possible.                      *
* Suggestions and comments are welcomed.  Please report any  *
* errors encountered in either the documentation or results  *
* immediately to LSTC through your site focus.               *
* Copyright (C) 1990-2011                                    *
* by Livermore Software Technology Corp. (LSTC)              *
* All rights reserved                                        *
Beginning of keyword reader                                03/15/17 13:30:55
contracting memory to           1 beginning of keyword reader
expanding   memory to      605876
expanding   memory to      755432
expanding   memory to      777208
expanding   memory to      798710
expanding   memory to      818710
expanding   memory to      838710
expanding   memory to      858710
expanding   memory to      882814
expanding   memory to      903214
expanding   memory to      930886
expanding   memory to     1083082
expanding   memory to     1110262
expanding   memory to     1164868
expanding   memory to     1190004
Memory required to process keyword     :      1190004
contracting memory to           1 end of keyword reader
LS-DYNA will perform a structural only analysis
                         ls-dyna ls971s.65543 R5.1.1    date 03/23/2011
expanding   memory to        2916 material, node and element data
expanding   memory to        3005 material properties
expanding   memory to       98394 element data for composite material
expanding   memory to      142801 gradient of damage data
expanding   memory to      659331 user control for contact interfaces
contracting memory to      659311 for boundary cond. vectorization
expanding   memory to      672901 arbitrary element numbering input
contracting memory to      659311 thick shell int. pt. strain
expanding   memory to      684320 spc cards
expanding   memory to      684375 rcforc moments
expanding   memory to     1982836 process element material data
expanding   memory to     1984872 load curve data
expanding   memory to     1985999 user_define_loading_set
expanding   memory to     1986227 regularize time history data
contracting memory to     1985999 rigidwall definitions
expanding   memory to     1999873 velocity b.c
expanding   memory to     2013710 nodal constraint sets
expanding   memory to     2014727 contact interfaces
expanding   memory to     2043399 implicit contact 1
expanding   memory to     2043401 implicit contact 2
expanding   memory to     2372400 contact segment data 1
contracting memory to     2346740 contact segment data 2
expanding   memory to     2465911 contact segment data 3
expanding   memory to     3304573 contact definition
expanding   memory to     3360251 rigid body
expanding   memory to     3953646 contact friction
expanding   memory to     3959412 rigid body b.c.
expanding   memory to     4365214 joints
contracting memory to     4365214 accelerometers
expanding   memory to     4365314 rigid bodies for disp. termination
contracting memory to     4365314 transformation to move nodes
expanding   memory to     4392986 interfac for file
contracting memory to     4379153 thermal expansion 0
expanding   memory to     4379156 flexible body 2
contracting memory to     4379156 implicit joints
expanding   memory to     4379159 minimum contact gap for auto switching
expanding   memory to     4433519 initialization phase
     slave surface of interface   =         2
     type                         =         3
     surface timestep             = 1.637E-06
     controlling slave node ID    =     11731
     part ID of slave node        =         1
     current minimum time step    = 1.637E-06
     master surface of interface  =         2
     type                         =         3
     surface timestep             = 2.825E-05
     controlling master node ID   =     11915
     part ID of master node       =         3
     slave surface of interface   =         1
     type                         =         3
     master surface of interface  =         1
     type                         =         3
     surface timestep             = 1.344E-04
     controlling master node ID   =     13019
     part ID of master node       =         4
     slave surface of interface   =         3
     type                         =         4
The LS-DYNA time step size should not exceed     1.637E-06
to avoid contact instabilities.  If the step size is
bigger then scale the penalty of the offending surface.
S t o r a g e   a l l o c a t i o n
Memory required to begin solution      :      4433519
Additional dynamically allocated memory:       678702
                                   Total:      5112221
      initial time step by element number
      controlling element is in square brackets
calculation with mass scaling for minimum dt
    added mass   =   2.1260E-03
    physical mass=   3.2161E+01
    ratio        =   6.6105E-05
       1 t 0.0000E+00 dt 9.00E-07 flush i/o buffers            03/15/17 13:30:56
       1 t 0.0000E+00 dt 9.00E-07 write d3plot file            03/15/17 13:30:56
    1000 t 8.9910E-04 dt 9.00E-07 flush i/o buffers            03/15/17 13:31:17
126000 t 1.1340E-01 dt 9.00E-07 flush i/o buffers            03/15/17 14:16:36
  126667 t 1.1400E-01 dt 9.00E-07 write d3plot file            03/15/17 14:16:52
  127000 t 1.1430E-01 dt 9.00E-07 flush i/o buffers            03/15/17 14:17:03
GMT+8, 2024-4-20 09:25 , Processed in 0.027865 second(s), 11 queries , Gzip On, MemCache On.
