- 2017-3-18
哪位大神解决下这个问题 同样的模型,一台电脑上建立模型能运行,另一台电脑上(都是6.13汉化版)就出现这种错误:The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. |
