- 2007-10-30
Nastran SOL 700 Update (2017.1)
Starting in Version 2017.1 there is a change in the execution of MSC Nastran SOL 700. Customers that have a lease
agreement will no longer be able to run MSC Nastran SOL 700 jobs. The binaries needed are usually located in the
msc20171/dyna directory of the Nastran installation. However this directory will be missing after the installation of
MSC Nastran 2017.1. When a user tries to execute a job for SOL 700, the following message will be issued by Nastran
in the f06 file:
SOL 700 with LS-Dyna is requested, but the installation of LS-Dyna seems to be missing. Please, download the
additional installer for LS-Dyna from the MSC Download Center and install it if you have a valid license under
maintenance.
Paid-up customers will have an option to download an addition installer from the SDC site. This installer only contains
the binaries needed for SOL 700 and it should be installed after the installation of the regular Nastran application. For
those customers, there will be no change in the FlexLM License features and the features can be used of MSC Nastran
version 2017.0.
MSC Nastran 2017.1以后的所有版本是不是再也不能用Sol 700了?
