- 2016-10-24
楼主 |
发表于 2017-4-28 20:54:42
来自 大连理工大学
我的log文件如下
baqus JOB 4272
Abaqus 6.14-1
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens from Flexnet server TJ-20140101SPKI.
<1019 out of 1024 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
2017/4/28 21:05:02
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.139 Build 20131008
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
C:\Users\Admin\AppData\Local\Temp\Admin_4272_13960\ss.for(1): (col. 18) remark: uel has been targeted for automatic cpu dispatch
End Compiling Abaqus/Standard User Subroutines
Begin Linking Abaqus/Standard User Subroutines
Creating library standardU.lib and object standardU.exp
libirc.lib(fast_mem_ops.obj) : warning LNK4210: .CRT section exists; there may be unhandled static initializers or terminators
End Linking Abaqus/Standard User Subroutines
2017/4/28 21:05:03
Begin Analysis Input File Processor
2017/4/28 21:05:03
Run pre.exe
2017/4/28 21:05:05
Abaqus Error: The executable pre.exe
aborted with system error code 1073741819.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
请问老师们如何解决这个问题呀? |
