查看: 122|回复: 3
[K文件] out-of-range velocity
发表于 2017-5-26 10:46:46 | 显示全部楼层 |阅读模式 来自 河南郑州
我在模拟煤体爆破的裂纹扩展,出现out-of-range velocity,
*** Error 40500 (SOL+500)
     node # 82314 has out-of-range velocities
       x-velocity= NaN
       y-velocity= NaN
       z-velocity= NaN
     node # 82315 has out-of-range velocities
       x-velocity= NaN
       y-velocity= NaN
       z-velocity= NaN
我把部分K文件摘下来(因为文件太大,只能是部分),请各位大神指点,也可以QQ邮箱:56653648@qq.com联系我,谢谢!
$                             SECTION DEFINITIONS                              $
*SECTION_SOLID
         1         1
*SECTION_SOLID_ALE
         2        11
*CONTROL_ALE
         2         1         4-1.0000000 0.0000000 0.0000000 0.0000000
*ALE_MULTI-MATERIAL_GROUP
         2         1
*constrained_lagrange_in_solid
1,2,0,0,3,5,2,1
0,1.0E10,0.1,0.0,0.5,0,0,0.0
0.0,0.0,0.0,0,0.3,0,0,0
*SET_PART_LIST
*SET_PART_LIST
         2
         2
$                             MATERIAL DEFINITIONS                             $
*MAT_JOHNSON_HOLMQUIST_CONCRETE
1,1.86,0.141,0.79,1.60,0.007,0.61,0.048E-2
4.0E-5,1.0E-6,0.010,7.0,1.6E-4,0.001,8E-3,0.100
0.040,1.000,0.85,-1.71,2.08
*MAT_ADD_EROSION
1,1234,1234,1234
-4.0E-5,1234,1234,1234,1234,1234,1234,1234
*MAT_HIGH_EXPLOSIVE_BURN
2,1.64,0.693,0.27,0.00
*EOS_JWL
2,3.74,3.23E-2,4.15,0.95,0.3,0.07,1.00
*INITIAL_DETONATION
1,2.5,2.5,80,0.0
*MAT_NULL
         3 0.120E-02  0.00      0.00      0.00      0.00      0.00      0.00
*EOS_LINEAR_POLYNOMIAL
         3  0.00      0.00      0.00      0.00      0.00      0.00      0.00
  0.00      0.00
$                              PARTS DEFINITIONS                               $
*PART
Part          1 for Mat         1 and Elem Type         1
         1         1         1         0         0         0         0
*PART
Part          2 for Mat         2 and Elem Type         2
         2         2         2         2         0         0         0
*PART
Part          3 for Mat         3 and Elem Type         1
         3         2         3         3         0         0         0
*BOUNDARY_SPC_SET
         3         0         0         1         0         0         0         0
$                              CONTACT DEFINITIONS                             $
$                              CONTROL OPTIONS                                 $
*CONTROL_ENERGY
         2         2         2         2
*CONTROL_SHELL
  20.0             1        -1         1         2         2         1
*CONTROL_TIMESTEP
    0.0000    0.9000         0  0.00      0.00
*CONTROL_TERMINATION
0.150E+04         0   0.00000   0.00000   0.00000
$                                 TIME HISTORY                                 $
*DATABASE_BINARY_D3PLOT
0.0050
*DATABASE_BINARY_D3THDT
1500.0
*DATABASE_BINARY_D3DUMP
       844
$                              DATABASE OPTIONS                                $
*DATABASE_EXTENT_BINARY
         0         0         3         1         0         0         0         0
         0         0         4         0         0         0
*END
发表于 2017-6-7 14:24:39 | 显示全部楼层 来自 北京
来过,谢谢:victory:
发表于 2018-3-1 09:50:38 | 显示全部楼层 来自 湖南长沙
你解决了这个问题吗
GMT+8, 2024-3-29 22:11 , Processed in 0.030172 second(s), 12 queries , Gzip On, MemCache On.
