*** ERROR *** CP = 22.698 TIME= 13:34:55
The outward normal unit vector of the sloshing surface in element 89655
is not consistent with one of the global Cartesian coordinate axes.
*** ERROR *** CP = 1.047 TIME= 11:02:08
The outward normal unit vector of the sloshing surface in element 648
is not consistent with the positive z axis of the global Cartesian
coordinate.
The gravity acceleration should be perpendicular to the free surface
using the ACEL command, when the sloshing effect is solved by
acoustics elements.
将重力给为Z方向后,得到如下错误
*** ERROR *** CP = 1.109 TIME= 11:03:23
coordinate.
