查看: 2346|回复: 10
[子程序/二次开发] Marc2016+vs2013+Intel fortran 2015
发表于 2017-6-11 00:44:23 | 显示全部楼层 |阅读模式 来自 荷兰
Installation for use of subroutines in Marc/Mentat:
(1) Visual studio 2013
(2) Intel Parallel Studio XE Composer Edition for Fortran 2015
(3) Marc/mentat 2016
1. These are the recommended versions in Marc 2016 release guide. Either visual studio 2013 community or visual studio 2013 professional can be used. Make sure Visual studio 2013  is installed at first, and then Fortran 2015.
2. When installing Fortran 2015, select "custom" installation. This will check if Fortran 2015 is configurated into visual studio 2013.
3. After installation, set 3 environment variables in the tab of "System variables" of your computer. These system variables are "include", "lib", and "path" respectively.
include
C:\Program Files (x86)\Intel\Composer XE 2015\compiler\include;C:\Program Files (x86)\Intel\Composer XE 2015\mkl\include;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\include;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1A\Include
lib
C:\Program Files (x86)\Intel\Composer XE 2015\compiler\lib\intel64;C:\Program Files (x86)\Intel\Composer XE 2015\mkl\lib\intel64;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\lib\amd64;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\lib;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1A\Lib\x64;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1A\Lib
path
C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Bin;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Bin\x64;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1A\Bin;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1A\Bin\x64;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64;C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\IDE;C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Tools;C:\Program Files (x86)\Intel\Composer XE 2015\bin;C:\Program Files (x86)\Intel\Composer XE 2015\bin\intel64;C:\Program Files (x86)\Intel\Composer XE 2015\redist\intel64\mkl
4. Add following commands to the beginning of "C:\MSC.Software\Marc\2016.0.0\marc2016\tools\include_win64.bat":
@call "C:\Program Files (x86)\Intel\Composer XE 2015\bin\ifortvars.bat"
@call "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\vcvarsall.bat" X64
@call "C:\Program Files (x86)\Intel\Composer XE 2015\bin\ipsxe-comp-vars.bat" intel64 vs2013
@call "C:\Program Files (x86)\Intel\Composer XE 2015\bin\compilervars" intel64 vs2013
5. For more information, read "readme.txt" at "C:\MSC.Software\Marc\2016.0.0".
 楼主| 发表于 2017-12-3 19:28:45 | 显示全部楼层 来自 欧洲和中东地区
xj2330 发表于 2017-7-19 18:07
楼主,Marc2016能否使用Intel fortran 2013
这个没有测试过,一般都是使用推荐的版本。
回复 1 不支持 0
发表于 2017-7-19 18:07:18 | 显示全部楼层 来自 辽宁大连
发表于 2017-11-27 08:55:25 | 显示全部楼层 来自 江苏南京
好贴好贴好贴好贴
发表于 2018-9-1 15:43:55 | 显示全部楼层 来自 浙江温州
多谢多谢,帮了大忙
发表于 2018-10-5 20:17:58 | 显示全部楼层 来自 河北
太好了太好了
发表于 2018-10-10 09:32:52 | 显示全部楼层 来自 湖南长沙
下不到fortran2015
发表于 2019-1-2 09:50:37 | 显示全部楼层 来自 中国
十分感谢。终于可以链接到子程序了。这期间经历了无数次的卸载重装,都快被折磨崩溃了。还好看到了你发的帖子。真心感谢!
发表于 2019-8-8 16:48:45 | 显示全部楼层 来自 山东威海
感谢楼主,试一试。
发表于 2019-12-7 21:14:13 | 显示全部楼层 来自 山西太原
你好楼主,marc2018是否可以使用vs2013与ivf2013
发表于 2022-2-14 16:39:01 | 显示全部楼层 来自 浙江杭州
VS2015+Fortran2017+marc2018
GMT+8, 2024-4-28 20:43 , Processed in 0.035851 second(s), 11 queries , Gzip On, MemCache On.
