建立好模型之后,在Hypermesh中划分的网格,导入到VL里,结构模态可以算,但是算在空气中的声学响应的时候,会报错,显示错误信息如下,已经全面检查调整过网格了,依然还是会报错,只是每次报的单元编号不同,个人感觉是结构网格没有识别出来,但是按照报错的编号去找,发现这些单元都位于平整区域的中间,没有什么问题,请指教这是什么原因引起的报错,应该怎么修改,现在像无头苍蝇一样改真的难受,请各位大神指导一下报错信息:
Building Structural FEM/Acoustic BEM interface
Using Model 1 as Structural FEM Model
Using MOdel 2 as Acoustic BEM Model
There are 50392 interface node(s) on the structural FEM side
There are 60593 interface node(s) on the BEM side
ERROR in the interface definition,FEM Element 47660
****ERROR has occurred during computation****
You may try to compute the solution in manual mode and try to attach the results afterwards.
ERROR in the interface definition,FEM Element 47661
ERROR in the interface definition,FEM Element 47662
ERROR in the interface definition,FEM Element 47669
ERROR in the interface definition,FEM Element 47671
ERROR in the interface definition,FEM Element 47673
