查看: 98|回复: 1
[子程序/二次开发] 求助 marc 子程序 二次开发安装软件出现问题 LNK1181 怎么解决
发表于 2017-8-9 20:45:29 | 显示全部楼层 |阅读模式 来自 韩国
运行结果这样
Marc 2011.1.0 , Build  124518  Windows_NT version
Program name         : marc
Job ID               : D:\Marc WU\heat conduction\case5-heat flux 15-1mm-subroutine\heat5_job1
Version type         : i4
User subroutine name : flux1
User objects/libs    :
Restart file job ID  :
Substructure file ID :
Post file job ID     :
Defaults file ID     :
View factor file ID  :
Save generated module: no
MPI library          : intel-mpi
Auto restart         : 0
Contact decoupling   : 0
DDM processes        : 0
Solver processes     : 4
Host file            :
Distributed i/o      :
Run directory        : D:\Marc WU\heat conduction\case5-heat flux 15-1mm-subroutine
Scratch directory    : D:\Marc WU\heat conduction\case5-heat flux 15-1mm-subroutine
Default bin directory: C:\MSC.Software\Marc\2011\marc2011\bin\win64
Material database    : C:\MSC.Software\Marc\2011\marc2011\AF_flowmat\
ifort  /fpp /c /DWIN32_intel  -D_IMPLICITNONE /nologo   -DOPENMP -DMKL -D_MSCMARC -DWIN64 /I"C:\MSC.Software\Marc\2011\marc2011\common" /I"C:\MSC.Software\Marc\2011\marc2011\bcssolver\common" /I"C:\MSC.Software\Marc\2011\marc2011\mumpssolver\include" /I"C:\MSC.Software\Marc\2011\marc2011\intelmpi\win64\include" /O2 /Qip /Qsave /Qzero /Qvec- /switch:fe_old_modvar /W0   -DCASI -DPARDISO -DMUMPS /MD -DDDM /object:"D:\Marc WU\heat conduction\case5-heat flux 15-1mm-subroutine\flux1.obj"  "D:\Marc WU\heat conduction\case5-heat flux 15-1mm-subroutine\flux1.f"
LINK /nologo  /out:"flux1.exe" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\main.obj" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\blkdta.obj" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\comm1.obj" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\comm2.obj" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\comm3.obj" "D:\Marc WU\heat conduction\case5-heat flux 15-1mm-subroutine\flux1.obj"  "C:\MSC.Software\Marc\2011\marc2011\lib\win64\srclib.lib" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\mcvfit.lib" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\mnflib.lib" ""C:\MSC.Software\Marc\2011\marc2011\lib\win64\md_user.lib"" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\mdsrc.lib"  "C:\MSC.Software\Marc\2011\marc2011\lib\win64\bcslib.lib" "C:\MSC.Software\Marc\2011\marc2011\intelmkl\win64\mkl_intel_lp64.lib" "C:\MSC.Software\Marc\2011\marc2011\intelmkl\win64\mkl_intel_thread.lib" "C:\MSC.Software\Marc\2011\marc2011\intelmkl\win64\mkl_core.lib" "C:\MSC.Software\Marc\2011\marc2011\intelmkl\win64\libguide.lib" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\blas_src.lib"  "C:\MSC.Software\Marc\2011\marc2011\lib\win64\casilib.lib" "C:\MSC.Software\Marc\2011\marc2011\intelmkl\win64\mkl_solver_lp64.lib"  "C:\MSC.Software\Marc\2011\marc2011\lib\win64\mumps.lib" "C:\MSC.Software\Marc\2011\marc2011\intelmkl\win64\mkl_scalapack_lp64.lib" "C:\MSC.Software\Marc\2011\marc2011\intelmkl\win64\mkl_lapack95_lp64.lib"  ""C:\MSC.Software\Marc\2011\marc2011\intelmkl\win64\mkl_blacs_intelmpi_lp64.lib""    "C:\MSC.Software\Marc\2011\marc2011\lib\win64\stubs.lib" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\clib.lib" "C:\MSC.Software\Marc\2011\marc2011\lib\win64\metislib.lib" "C:\MSC.Software\Marc\2011\marc2011\xdr_lib\win64\xdr_irc.lib" /release /subsystem:console /incremental:no /nodefaultlib:libc.lib /nodefaultlib:libcmt.lib /nodefaultlib:libifcoremt.lib libmmd.lib libifcoremd.lib /LIBPATH:"C:\MSC.Software\Marc\2011\marc2011\intelmpi\win64\lib" impi.lib ws2_32.lib kernel32.lib user32.lib netapi32.lib advapi32.lib comdlg32.lib comctl32.lib
LINK : fatal error LNK1181: 无法打
link failed for flux1.obj
          Marc 2011.1.0 Exit number 3
 楼主| 发表于 2017-8-9 21:11:03 | 显示全部楼层 来自 韩国
忙了很久了 修改了环境参数等等 最后总是出现这个问题
GMT+8, 2024-4-17 00:12 , Processed in 0.025439 second(s), 11 queries , Gzip On, MemCache On.
