- 5
- 2010-1-2
如题,较小模型(50万单元以内)没有问题,较大模型(200万单元)就出现此问题,不能计算,网上说的方法都试过了,还是不行,请各路大侠指点,软件版本为6.14-1,系统为64位的windows server 2008.
以前在6.9版本计算过,模型规模和复杂程度差不多,计算正常完成。
Abaqus Error: The executable standard.exe
aborted with system error code 1073741819.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors |
