- 2009-11-24
做了一个圆形截面柱的cyclic loading 分析,分析完后打开数据记录文件查看位移和反应力,但是发现两个文件是空的,什么数据都没有记录下来,但是有时候会记录数据,但是和定义的位移值相比,差了很多数据,比如说如果我做了四个往复循环的加载,分别是加载到2mm, -2mm, 4mm, -4mm, 有时候记录了数据但是发现数据只记录到2mm,后面就没有了,而且位移的数据的数目和反应力的数据数目不一致,反应力的数据要少。有没有高手遇到过这种情况,请指点一二。将我的tcl文件附上,请大家给点意见。
# 2D circular cantilever column, reseved cyclic loading
# fiber section, nonlinearBeamColumn element
# Junhua Wang, Nanjing Tech University, 09.2017
# ^Y
# 2 __
# (1) LCol
# =1= _|_ -------->X
# SET UP ----------------------------------------------------------------------------
# units: N, mm, sec
wipe; # clear memory of all past model definitions
file mkdir Data; # create data directory
model BasicBuilder -ndm 2 -ndf 3; # Define the model builder, ndm=#dimension, ndf=#dofs
# define GEOMETRY -------------------------------------------------------------
set LCol 500; # column length
set Weight 1200000.; # superstructure weight
# define section geometry
set DCol 250; # Diameter of Column Depth
set RCol [expr $DCol/2]; # Radia of Cross-section of Column
# calculated parameters
set PCol $Weight; # nodal dead-load weight per column
set g 9800.0; # g.
set Mass [expr $PCol*2/$g]; # nodal mass
# calculated geometry parameters
set ACol [expr 3.14*pow($DCol,2)/4]; # cross-sectional area
set IzCol [expr 1./32.*3.14*pow($DCol,4)]; # Column moment of inertia
# nodal coordinates:
node 1 0 0; # node#, X, Y
node 2 0 $LCol
# Single point constraints -- Boundary Conditions
fix 1 1 1 1; # node DX DY RZ
# nodal masses:
mass 2 $Mass 1e-9 1e-9; # node#, Mx My Mz, Mass=Weight/g, neglect rotational inertia at nodes
# Define ELEMENTS & SECTIONS -------------------------------------------------------------
set ColSecTag 1; # assign a tag number to the column section
set coverCol 30; # Column cover to reinforcing steel NA.
set numBarsCol 8; # number of longitudinal-reinforcement bars in each side of column section. (symmetric top & bot)
set barAreaCol 125; # area of longitudinal-reinforcement bars
# MATERIAL parameters -------------------------------------------------------------------
set IDconcCore 1; # material ID tag -- confined core concrete
set IDconcCover 2; # material ID tag -- unconfined cover concrete
set IDreinf 3; # material ID tag -- reinforcement
# nominal concrete compressive strength
set fc -76.8; # CONCRETE Compressive Strength (+Tension, -Compression)
set Ec 32500.0; # Concrete Elastic Modulus
# unconfined concrete
set fc1U $fc; # UNCONFINED concrete (todeschini parabolic model), maximum stress
set K 1.2; # Enhanced ratio due to the lateral confinement
set fc2U [expr $fc*$K]; # Confined core concrete
set eps1U -0.003; # strain at maximum strength of unconfined concrete
set fc2U [expr 0.2*$fc1U]; # ultimate stress
set eps2U -0.1; # strain at ultimate stress
set lambda 0.5; # ratio between unloading slope at $eps2 and initial slope $Ec
# tensile-strength properties
set ftU [expr -0.14*$fc1U]; # tensile strength +tension
set Ets [expr $Ec*0.5]; # tension softening stiffness
set Fy 1423.0; # STEEL yield stress
set Es 210000; # modulus of steel
set Bs 0.01; # strain-hardening ratio
set R0 18; # control the transition from elastic to plastic branches
set cR1 0.925; # control the transition from elastic to plastic branches
set cR2 0.15; # control the transition from elastic to plastic branches
uniaxialMaterial Concrete02 $IDconcCover $fc1U $eps1U $fc2U $eps2U $lambda $ftU $Ets; # build cover concrete (unconfined)
uniaxialMaterial Concrete02 $IDconcCore $fc2U $eps1U $fc2U $eps2U $lambda $ftU $Ets; # build cover concrete (confined)
uniaxialMaterial Steel02 $IDreinf $Fy $Es $Bs $R0 $cR1 $cR2; # build reinforcement material
# FIBER SECTION properties -------------------------------------------------------------
# symmetric section
# y
# | o o o | | -- cover
# z <--- | + | H
# |-------- B --------|
# RC section:
section fiberSec $ColSecTag {; # Define the fiber section
set ncore1 8; # the devision number of core concrete in circumferential direction
set ncore2 8; # the devision number of core concrete in radial direction
set mcover1 4; # the devision number of cover concrete in circumferential direction
set mcover2 4; # the devision number of cover concrete in radial direction
set Rcover [expr $RCol-$coverCol];
patch circ $IDconcCore $ncore1 $ncore2 0.0 0.0 0.0 $Rcover 0 360
patch circ $IDconcCover $mcover1 $mcover2 0.0 0.0 $Rcover $RCol 0 360
layer circ $IDreinf $numBarsCol $barAreaCol 0.0 0.0 $Rcover 0 360
}; # end of fibersection definition
# define geometric transformation: performs a linear geometric transformation of beam stiffness and resisting force from the basic system to the global-coordinate system
set ColTransfTag 1; # associate a tag to column transformation
geomTransf Linear $ColTransfTag ;
# element connectivity:
set numIntgrPts 6; # number of integration points for force-based element
element nonlinearBeamColumn 1 1 2 $numIntgrPts $ColSecTag $ColTransfTag; # self-explanatory when using variables
# element forceBeamColumn $eleTag $iNode $jNode $transfTag "HingeRadau $secTagI $LpI $secTagJ $LpJ $secTagInterior"
# element forceBeamColumn 1 1 2 $ColTransfTag HingeRadau $ColSecTag 350.0 $ColSecTag 0.0 $ColSecTag
# define GRAVITY -------------------------------------------------------------
pattern Plain 1 Linear {
load 2 0 -$PCol 0
# Gravity-analysis parameters -- load-controlled static analysis
set Tol 1.0e-8; # convergence tolerance for test
constraints Plain; # how it handles boundary conditions
numberer Plain; # renumber dof's to minimize band-width (optimization), if you want to
system BandGeneral; # how to store and solve the system of equations in the analysis
test NormDispIncr $Tol 6 ; # determine if convergence has been achieved at the end of an iteration step
algorithm Newton; # use Newton's solution algorithm: updates tangent stiffness at every iteration
set NstepGravity 10; # apply gravity in 10 steps
set DGravity [expr 1./$NstepGravity]; # first load increment;
integrator LoadControl $DGravity; # determine the next time step for an analysis
analysis Static; # define type of analysis static or transient
analyze $NstepGravity; # apply gravity
# ------------------------------------------------- maintain constant gravity loads and reset time to zero
loadConst -time 0.0
puts "Model Built"
pattern Plain 2 Linear {
load 2 $PCol 0 0;
constraints Plain;
numberer Plain;
system SparseGeneral -piv;
test NormDispIncr 1e-8 1000;
algorithm KrylovNewton;
analysis Static;
foreach Dincr { 0.1 -0.1 0.1 -0.1 0.2 -0.2 0.2 -0.2} {
integrator DisplacementControl 2 1 $Dincr
analyze 10
# Define RECORDERS -------------------------------------------------------------
recorder Node -file Data/DFree.out -time -node 2 -dof 1 2 3 disp; # displacements of free nodes
recorder Node -file Data/RBase.out -time -node 1 -dof 1 2 3 reaction; # support reaction
puts "Reserved cyclic loading Analysis done";
