- 2017-11-16
ABAQUS警告Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc.
For *tie pair (assembly_surf-top-y-assembly_surf-beam-ys), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_surf-bot-y-assembly_surf-beam-yx), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_surf-top-z-assembly_surf-beam-zs), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_surf-bot-z-assembly_surf-beam-zx), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
MPCS (EXTERNAL or INTERNAL, including those generated from rigid body definitions), KINEMATIC COUPLINGS, AND/OR EQUATIONS WILL ACTIVATE ADDITIONAL DEGREES OF FREEDOM
求助大神 |
