热应力分析时,热膨胀系数与温度有关,
结果在求解时,弹出
The reference temperature for the thermal expansion coefficient differs from the reference temperature of one or more bodies. The data will be adjusted to have a zero thermal strain at the reference temperature of each body. If the number of temperature points is sparse this could cause invalid values to be used for calculations. The recommendation is to have the same reference temperature on the bodies as the thermal expansion coefficient's reference temperature in Engineering Data or a dense number of temperature points.
