查看: 46|回复: 0
The Distributed ANSYS solution currently only supports single field physics
发表于 2018-3-21 21:26:59 | 显示全部楼层 |阅读模式 来自 江苏南京
The Distributed ANSYS solution currently only supports single field physics such as: structural(UX,UY,UZ,ROTX,ROTY,ROTZ,WARP) single field thermal(TEMP), electric(VOLT), magnetic (AX,AY,AZ) solutions and others.
这个问题怎么解决,谢谢大佬!
GMT+8, 2024-4-16 21:39 , Processed in 0.027557 second(s), 11 queries , Gzip On, MemCache On.
