我在建模过程中,使用beam188单元建立铁塔,mpc184单元建立绝缘子,link10单元建立导线,三者连接处都有共用节点,边界条件都设置了,但在施加重力加速度计算时一直算不了,请问连接处需要特殊处理吗? 以下的节点都是导线上的节点,求大神指点! *** WARNING *** SUPPRESSED MESSAGE CP = 1039.656 TIME= 09:34:51
There is at least 1 small equation solver pivot term (e.g., at the UX
degree of freedom of node 1) which may indicate a numerically unstable
model. Please check your results carefully.
*** ERROR *** SUPPRESSED MESSAGE CP = 1039.719 TIME= 09:34:51
The value of UX at node 44124 is 9.259705723E+10. It is greater than
the current limit of 1000000 (which can be reset on the NCNV command).
This generally indicates rigid body motion as a result of an
unconstrained model. Verify that your model is properly constrained.
*** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***
Rigid body motion can also occur when net section yielding has
occurred resulting in large displacements for small increments of load
or when buckling has occurred. You can plot the time history curve
for node 44124 in the UX direction to check for stiffness (slope of
the curve) approaching zero.
*** WARNING *** SUPPRESSED MESSAGE CP = 1057.062 TIME= 09:35:00
*** ERROR *** SUPPRESSED MESSAGE CP = 1057.094 TIME= 09:35:00
The value of UX at node 43480 is 3.374903337E+21. It is greater than
*** WARNING *** SUPPRESSED MESSAGE CP = 1057.094 TIME= 09:35:00
The unconverged solution (identified as time 1 substep 999999) is
output for analysis debug purposes. Results should not be used for
any other purpose.
