1.*inelastic heat fraction and *specific heat are only used in an adiabatic analysis and a coupled temperature-displacement analysis
2.*inelastic heat fraction and *specific heat are only used in an adiabatic analysis and a coupled temperature-displacement analysis
3.*inelastic heat fraction and *specific heat are only used in an adiabatic analysis and a coupled temperature-displacement analysis
4.*The *INELASTIC HEAT FRACTION option is only meaningful for materials with dissipative properties (*PLASTIC, *VISCOELASTIC, or user material). The inelastic heat fraction will be ignored for this material definition.
5.The parameter hourglass on the *section controls option is relevant for solid, membrane, and shell elements with reduced integration wherever applicable. This warning can be ignored if the feature is applied to these element types only.
6.The parameter distortion control on the *section controls option is relevant for solid elements wherever applicable. This warning can be ignored if the feature is applied to solid elements only.
7.The parameter hourglass on the *section controls option is relevant for solid, membrane, and shell elements with reduced integration wherever applicable. This warning can be ignored if the feature is applied to these element types only.
8.For two-dimensional models, if a non-unity thickness is specified for two-dimensional solid elements and these elements are involved in an interaction such as contact, the same thickness should be specified for the out-of-plane thickness of the corresponding surface under *surface interaction.
9.Output request evf is not available for element type cpe4rt
10.Output request peeqvavg is not available for element type cpe4rt
11.Output request pevavg is not available for element type cpe4rt
12.Output request svavg is not available for element type cpe4rt
13.Output request evf is not available for element type cpe4rt
14.Output request peeqvavg is not available for element type cpe4rt
15.Output request pevavg is not available for element type cpe4rt
16.Output request svavg is not available for element type cpe4rt
17.Output request dmicrt is not available for the material for element type cpe4rt
18.Output request evf is not available for element type cpe4rt
19.Output request peeqvavg is not available for element type cpe4rt
20.Output request pevavg is not available for element type cpe4rt
21.Output request sdeg is not available for the material for element type cpe4rt
22.Output request svavg is not available for element type cpe4rt
23.Output request evf is not available for element type cpe4rt
24.Output request peeqvavg is not available for element type cpe4rt
25.Output request pevavg is not available for element type cpe4rt
26.Output request svavg is not available for element type cpe4rt
27.NO SEPARATION surface behavior specified in conjunction with balanced master-slave contact may overconstrain the contact interface, causing unstable behavior and/or inaccurate results. See the contact pair defined between surfaces ASSEMBLY_CHIP_BOT and ASSEMBLY_JOINT_TOP.
28.NO SEPARATION surface behavior specified in conjunction with balanced master-slave contact may overconstrain the contact interface, causing unstable behavior and/or inaccurate results. See the contact pair defined between surfaces ASSEMBLY_WORK_TOP and ASSEMBLY_JOINT_BOT.
29.There are 28 warning messages in the data (.dat) file. Please check the data file for possible errors in the input file.
30ASSEMBLY_TOOL_FACE is a rigid surface, so it will be made the master surface in the contact pair with surface ASSEMBLY_CHIP_BOT. The WEIGHT value reported in the .dat file for this contact pair is not correct.
31.The elements in element set WarnElemFailElemInContact are part of a deformable surface that is referenced by a *CONTACT PAIR option in addition to having material properties that allow the element to fail. For elements that can fail, contact should be defined using the *CONTACT option.
32.Boundary conditions are defined at the nodes contained in node set WarnNodeBcIntersectKinCon. In addition the nodes are also part of a surface involved in kinematic contact. The kinematic contact constraint will be overridden by the boundary conditions in case of a conflict. Penalty contact may be used instead.
33.Thermal contact between surfaces ASSEMBLY_CHIP_BOT and ASSEMBLY_JOINT_TOP is causing a 99.610% reduction in the time increment.
