The slave surface assembly_soil-1 has 12 nodes in common with its master surface assembly_pile-1.
The slave surface assembly_soil-2 has 3 nodes in common with its master surface assembly_pile-2.
*mohr coulomb requires the use of *elastic,type=iso
Permeability is specified on 1456 elements but the initial void ratio is not defined. Use *initial conditions to the value. The elements are identified in element set ErrElemPermNoInitVoidRatio.
Analysis Input File Processor exited with an error.
