- 2018-5-4
说是什么连接到分析的问题,但是我又没定义接触也没用子程序,错误代码是1073741795
急求解答!以下是报错全文:
ERROR in job messaging system: Error in connection to analysis
Error in job Job-lifangti: The executable standard.exe aborted with system error code 1073741795. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job Job-lifangti aborted due to errors. |
