***WARNING: THE SUPERELASTICITY ALGORITHM DID NOT CONVERGE AT 6 POINTS
***NOTE: MATERIAL CALCULATIONS FAILED TO CONVERGE OR WERE NOT ATTEMPTED AT ONE
OR MORE POINTS. CONVERGENCE IS JUDGED UNLIKELY.
***WARNING: THE SYSTEM MATRIX HAS 13 NEGATIVE EIGENVALUES.
EXPLANATIONS ARE SUGGESTED AFTER THE FIRST OCCURRENCE OF THIS MESSAGE.
CONTACT PAIR (ASSEMBLY_SURF-STENT-CONTACT,ASSEMBLY_M_SURF-10) NODE
STENT-ABAQUS-1.7523 IS OVERCLOSED BY 3.67715E-06.
***WARNING: THE SUPERELASTICITY ALGORITHM DID NOT CONVERGE AT 881 POINTS
***WARNING: THE SUPERELASTICITY ALGORITHM DID NOT CONVERGE AT 2 POINTS
***ERROR: TOO MANY ATTEMPTS MADE FOR THIS INCREMENT
