查看: 68|回复: 1
压杆稳定性分析
发表于 2018-5-19 19:05:12 | 显示全部楼层 |阅读模式 来自 湖北武汉
再求解屈曲分析时,出现了Block Lanczos solver failure.  The assembled stress stiffness matrix contains all zeroes.  No load factor solution is possible. 的错误。
命令流如下,
/PREP7
ET,1,BEAM188
KEYOPT,1,1,1
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.1e11
MPDATA,PRXY,1,,0.3
SECTYPE,   1, BEAM, CSOLID, , 0
SECOFFSET, CENT
SECDATA,50,0,0,0,0,0,0,0,0,0,0,0
K, ,0,0,0,
K, ,5000,0,0,
K, ,15000,0,0,
LSTR,       1,       2
LSTR,       2,       3
TYPE,   1
MAT,       1
REAL,
ESYS,       0
SECNUM,   1
FLST,5,2,4,ORDE,2
FITEM,5,1
FITEM,5,-2
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1,100, , , , , , ,1
FLST,2,2,4,ORDE,2
FITEM,2,1
FITEM,2,-2
LMESH,P51X
FINISH
/SOL
ANTYPE,0
PSTRES,1
FLST,2,1,3,ORDE,1
FITEM,2,1
/GO
DK,P51X, , , ,0,ALL, , , , , ,
FLST,2,2,3,ORDE,2
FITEM,2,2
FITEM,2,-3
/GO
DK,P51X, , , ,0,UX,UY,UZ, , , ,
FLST,2,1,3,ORDE,1
FITEM,2,1
/GO
FK,P51X,FX,7860
FLST,2,1,3,ORDE,1
FITEM,2,3
/GO
FK,P51X,FX,-7860
/STATUS,SOLU
SOLVE
FINISH
/SOL
ANTYPE,1
BUCOPT,LANB,1,0,0,CENTER
MXPAND,1,0,0,0,0.001,
/STATUS,SOLU
SOLVE
求大神解惑
 楼主| 发表于 2018-5-19 19:40:03 | 显示全部楼层 来自 湖北武汉
约束施加有问题,改成
FLST,2,1,3,ORDE,1
FITEM,2,1
/GO
DK,P51X, , , ,0,UX,UY,UZ,ROTY, , ,
FLST,2,2,3,ORDE,2
FITEM,2,2
FITEM,2,-3
/GO
DK,P51X, , , ,0,UY,UZ,ROTY, , , ,
后,提示Repeated Lanczos shift and factorize steps did not yield additional buckling modes in the requested eigenvalue range.  Either the modes are widely separated or, there are only 0 modes in the neighborhood specified by SHIFT value in BUCOPT command.
GMT+8, 2024-4-16 12:37 , Processed in 0.049677 second(s), 11 queries , Gzip On, MemCache On.
