该模型为三层圆饼的柱状模型,注水点应设置在圆柱上表面中心处(其实这里的inp文件的注水相关语句无法确定),因为还在摸索练习选择了提交job,之后就在abaqus中运行后弹出这个提醒:
The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. 参考现有的有限资料重新建模多次,该问题始终无法解决,不知材料或装配等哪里出现问题,非常不解。现将inp文件以txt附上,望各位大触不吝赐教。 初学仿真,因为没有师兄老师指教,问的问题很基础,非常不好意思以及非常的感谢。
祝大家工作学习顺利。
