- 2018-4-23
楼主 |
发表于 2018-7-19 13:53:22
来自 湖南长沙
我后面了解到这个材料模型只能通过修改k文件添加,不能进行前处理,其他材料可以,我改了k文件里面的材料,但是总是出现错误,不知道什么原因,麻烦您能帮我看一下吗
我改的材料如下:
*MAT_CONCRETE_DAMAGE_72REL3
3,0.24E+04,0.2
,-0.2E+08
,,,39.37,0.145E-3
4,0.25E+04,0.2
,-0.3E+08
,,,39.37,0.145E-3
错误如下:
*** Error 10246 (KEY+246)
line contains improperly formatted data
reading *MAT_CONCRETE_DAMAGE card.
At line# 186171 of file
f:\ansysj~1\kaochu~1.k
At line# 186175 of file
*** Error 10157 (KEY+157)
MAT 4 is not found
MAT 3 is not found
expanding memory to 19301892
expanding memory to 19335142
*** Error 10304 (KEY+304)
CHECKING MATERIAL INPUT Part ID= 3
PART ID 3 with
SECTION ID 1 and
MATERIAL ID 4 does not exist.
This is PART 3 in the order of input.
CHECKING MATERIAL INPUT Part ID= 5
PART ID 5 with
SECTION ID 1 and
MATERIAL ID 3 does not exist.
This is PART 5 in the order of input. |
