错误中是:
in keyword *EMBEDDEDELEMENT, file "practice-1.inp", line 10419: Unknown assembly set STEEL
There are no embedded elements specified under the *embedded element card.
警告中是:
Elset assembly_steel has been defined as a embedded element set. This element set is not active in the current model
Strain output request le is not valid for some elements in this analysis. This request is switched to the strain measure, e.
