NOTE # 9199
MSGLMT=STRICT is active, all messages will be printed.
You can suppress some less important warning messages by use of
MSGLMT=BRIEF or UNREF (in config file or in the input data).
1 PARAM(s) were set:
MODETRAK,YES
NOTE # 1929
Created RAM scratch area: total size 30 MB.
*** ERROR # 5617 ***
The SUBCASE ID in ATT1 field of DRESP1 2 does not refer to a modal FRF subcase.
*** ERROR # 5616 ***
The ATT1 field in DRESP1 2 refers to unknown SUBCASE ID 1.
The SUBCASE ID in ATT1 field of DRESP1 3 does not refer to a modal FRF subcase.
The ATT1 field in DRESP1 3 refers to unknown SUBCASE ID 1.
*** Errors with missing, incorrect or duplicate IDs found 5616 times.
IN ADDITION 30 MB RAMDISK AREA WAS ALLOCATED IN MEMORY
MAXIMUM DISK SPACE USED 1 MB
