- 2018-10-30
最近在做一个二维抗滑桩桩边坡降雨稳定性分析,老是算结果的时候终止了,以下是警告里面的文字,望大神帮忙解答下,谢谢。
No pore fluid flow will occur across slave surface assembly_soil-1_soil-1 and master surface assembly_pile-1_pile-1.
No pore fluid flow will occur across slave surface assembly_soil-1_soil-2 and master surface assembly_pile-1_pile-2.
No pore fluid flow will occur across slave surface assembly_soil-1_soil-3 and master surface assembly_pile-1_pile-3.
Sorption scanning slope will be generated by the program
The dilation angle is small or zero. The value will be set to 0.10000
The slave surfaces, assembly_soil-1_soil-1 and assembly_soil-1_soil-3 intersect each other and are paired with master surfaces that intersect each other as well. If fluid flow occurs, the common nodes on the slave surfaces may not transfer fluid properly. A remedy is to merge surfaces as much as possible.
The slave surfaces, assembly_soil-1_soil-2 and assembly_soil-1_soil-3 intersect each other and are paired with master surfaces that intersect each other as well. If fluid flow occurs, the common nodes on the slave surfaces may not transfer fluid properly. A remedy is to merge surfaces as much as possible.
THE SLAVE SURFACES ASSEMBLY_SOIL-1_SOIL-1 AND ASSEMBLY_SOIL-1_SOIL-3 INTERSECT EACH OTHER. THEY ARE PAIRED WITH MASTER SURFACES ASSEMBLY_PILE-1_PILE-1 AND ASSEMBLY_PILE-1_PILE-3 THAT ALSO INTERSECT EACH OTHER. IF BOTH PAIRS ARE *CONTACT PAIRs, THESE TWO PAIRS SHOULD NOT BE SIMULTANEOUSLY PRESENT IN A STEP BECAUSE OF POSSIBLE CONVERGENCE PROBLEMS; USE *MODEL CHANGE,TYPE=CONTACT PAIR TO REMOVE ONE OF THEM. IF BOTH ARE *TIE PAIRS, THE REDUNDANT TIES WILL BE REMOVED AUTOMATICALLY. IF ONE PAIR IS *TIE AND ANOTHER IS *CONTACT PAIR, REMOVE ONE OF THEM.
THE SLAVE SURFACES ASSEMBLY_SOIL-1_SOIL-2 AND ASSEMBLY_SOIL-1_SOIL-3 INTERSECT EACH OTHER. THEY ARE PAIRED WITH MASTER SURFACES ASSEMBLY_PILE-1_PILE-2 AND ASSEMBLY_PILE-1_PILE-3 THAT ALSO INTERSECT EACH OTHER. IF BOTH PAIRS ARE *CONTACT PAIRs, THESE TWO PAIRS SHOULD NOT BE SIMULTANEOUSLY PRESENT IN A STEP BECAUSE OF POSSIBLE CONVERGENCE PROBLEMS; USE *MODEL CHANGE,TYPE=CONTACT PAIR TO REMOVE ONE OF THEM. IF BOTH ARE *TIE PAIRS, THE REDUNDANT TIES WILL BE REMOVED AUTOMATICALLY. IF ONE PAIR IS *TIE AND ANOTHER IS *CONTACT PAIR, REMOVE ONE OF THEM.
For contact pair (assembly_soil-1_soil-1-assembly_pile-1_pile-1), adjustment was specified but no node was adjusted more than the adjustment distance = 2.22000e-16.
For contact pair (assembly_soil-1_soil-2-assembly_pile-1_pile-2), adjustment was specified but no node was adjusted more than the adjustment distance = 2.22000e-16.
For contact pair (assembly_soil-1_soil-3-assembly_pile-1_pile-3), adjustment was specified but no node was adjusted more than the adjustment distance = 2.22000e-16.
Strain output request le is not valid for some elements in this analysis. This request is switched to the strain measure, e.
Output request flvel is not available for element type cpe4r
Output request pe is not available for element type cpe4r
Output request peeq is not available for element type cpe4r
Output request pemag is not available for element type cpe4r
Output request s is not available for element type cpe4r
Output request sat is not available for element type cpe4r
Output request voidr is not available for element type cpe4r
Output request e is not available for element type cpe4r
Output request flvel is not available for element type cpe4p
Output request pe is not available for element type cpe4p
Output request peeq is not available for element type cpe4p
Output request pemag is not available for element type cpe4p
Output request s is not available for element type cpe4p
Output request sat is not available for element type cpe4p
Output request voidr is not available for element type cpe4p
Output request e is not available for element type cpe4p
Output request pfl is not available for contact pair assembly_soil-1_soil-1-assembly_pile-1_pile-1
Output request pfla is not available for contact pair assembly_soil-1_soil-1-assembly_pile-1_pile-1
Output request ptl is not available for contact pair assembly_soil-1_soil-1-assembly_pile-1_pile-1
Output request ptla is not available for contact pair assembly_soil-1_soil-1-assembly_pile-1_pile-1
Output request pfl is not available for contact pair assembly_soil-1_soil-2-assembly_pile-1_pile-2
Output request pfla is not available for contact pair assembly_soil-1_soil-2-assembly_pile-1_pile-2
Output request ptl is not available for contact pair assembly_soil-1_soil-2-assembly_pile-1_pile-2
Output request ptla is not available for contact pair assembly_soil-1_soil-2-assembly_pile-1_pile-2
Output request pfl is not available for contact pair assembly_soil-1_soil-3-assembly_pile-1_pile-3
Output request pfla is not available for contact pair assembly_soil-1_soil-3-assembly_pile-1_pile-3
Output request ptl is not available for contact pair assembly_soil-1_soil-3-assembly_pile-1_pile-3
Output request ptla is not available for contact pair assembly_soil-1_soil-3-assembly_pile-1_pile-3 |
