neper--相信做晶粒的大家都不陌生了,今天就再来介绍这块强大的linux下的voronoi建模软件。 网址:http://neper.sourceforge.net/
缺点:一款全新软件需要长时间学习;需要熟悉linux操作及命令;此软件使用人较少,缺少讨论对象
优点:除了缺点,嘿嘿
基本介绍:
[tr]Neper: polycrystal generation and meshing[tr]Neper is a software package for polycrystal generation and meshing. It can deal with 2D and 3D polycrystals with very large numbers of grains. Its main features are: Generation of polycrystals from (experimental) morphological properties [tr]Standard approaches (regular tessellations and Voronoi or Laguerre tessellations) are also available.
- [tr]Grain size distribution, grain shape distribution, etc.
- [tr]Grain-by-grain data as obtained for example in synchrotron X-ray diffraction (3DXRD, DCT, HEDM, ...) and such as grain centroids/volumes or a full polycrystal image.
Generation of multiscale microstructures [tr]Each cell of a primary tessellation is partitioned into a new tessellation, and the process can be repeated an arbitrary number of times. This can be used to mode complex microstructures such as bainitic steel, lamellar Ti-6Al-4V, etc. Generation of periodic or semi-periodic microstructures [tr]The tessellations (and their meshes) can be prescribed periodic or semi-periodic conditions to cancel the effect of free surfaces or reduce the size of the RVE. NEW (version 3.3): Generation of uniform orientation distributions [tr]Orientations can be uniformly distributed (flat ODF) for any number of orientations and any crystal symmetry. Some orientations can even be prescribed. Meshing into good-quality elements [tr]Meshing involves specific methods called regularization, multimeshing and remeshing. The mesh size can be uniform or defined on a per-grain basis. Meshing with cohesive elements at interfaces Visualization and analysis of the tessellations and meshes [tr]The scene can be set in great detail and images are generated with publication-quality rendering (see the image on the right). Several metrics are available on the morphological and topological properties.
[tr]Neper is built around three modules: generation, meshing and visualization. All the input data are prescribed non-interactively, using command lines and / or ASCII files. Neper can be compiled and run on any Unix-like system. [tr]下面只放效果图了,详细的自己去官网看(包括软件下载): [tr] [tr]
| 网格划分:
可视化:
应用: 20192018- [tr]D. Zhu, S. Tu, H. Ma, H. Wei, H. Li and C. Wang,
Modeling and calculating for the compaction characteristics of waste rock masses, International Journal for Numerical and Analytical Methods in Geomechanics [tr], doi:10.1002/nag.2862. - [tr]J.V. Kobylinski, R. Lawitzki, M. Hofmann, C. Krempaszky and E. Werner,
Micromechanical behaviour of Ni-based superalloys close to the yield point: a comparative study between neutron diffraction on different polycrystalline microstructures and crystal plasticity finite element modelling, Continuum Mechanics and Thermodynamics [tr], doi:10.1007/s00161-018-0720-0.
- [tr]M. Marvi-Mashhadi, C.S. Lopez and J. LLorca,
Effect polyurethane foams: an experimental and numerical study, Mechanics of Materials [tr], doi:10.1016/j.mechmat.2018.06.006.
- [tr]B. Hudobivnik, F. Aldakheel and P. Wriggers,
A low order 3D virtual element formulation for finite elasto–plastic deformations, Computational Mechanics [tr], doi:10.1007/s00466-018-1593-6. - [tr]A.A. El-Aty, Y. Xu, S. Ha and S.-H. Zhang,
Computational homogenization of tensile deformation behaviors of a third generation Al-Li alloy 2060-T8 using crystal plasticity finite element method, Materials Science and Engineering: A [tr], doi:10.1016/j.msea.2018.06.088.
- [tr]I. Benedetti and V. Gulizzi,
A grain-scale model for high-cycle fatigue degradation in polycrystalline materials, International Journal of Fatigue [tr], pp. 90-105, vol. 116, 2018.
- [tr]S.I. Ranganathan, M.R. Murshed and L. Costa,
Heterogeneous Anisotropy Index and scaling in two-phase random polycrystals, Acta Mechanica [tr], doi:10.1007/s00707-018-2114-6.
2017
- [tr]N.Y. Juul, J. Oddershede, A. Beaudoin, K. Chatterjee, M.K.A. Koker, D. Dale, P. Shade and G. Winther,
Measured resolved shear stresses and Bishop-Hill stress states in individual grains of austenitic stainless steel, Acta Materialia [tr], doi:10.1016/j.actamat.2017.09.021.
- [tr]P.J. Zhao, Z.H. Chen and C.F. Dong,
Investigation and prediction of tearing failure during extrusion based on a modified shear damage model, Mechanics of Materials [tr], doi:10.1016/j.mechmat.2017.05.008, 2017.
- [tr]Carson, M. Obstalecki, M. Miller and P. Dawson,
Characterizing Heterogeneous Intragranular Deformations in Polycrystalline Solids Using Diffraction-Based and Mechanics-Based Metrics, Modelling and Simulation in Materials Science and Engineering [tr], vol. 25, pp. 055008, 2017. made cover of the Journal
- [tr]V.P. Nguyen, C.T. Nguyen, T. Rabczuk and S. Natarajan,
On a family of convected particle domain interpolations in the material point method, Finite Elements in Analysis and Design [tr], vol. 126, pp. 50-64, 2017.
- [tr]M.R. Kabir and H. Richter,
Modeling of Processing-Induced Pore Morphology in an Additively-Manufactured Ti-6Al-4V Alloy, Materials [tr], vol. 10, p. 35, 2017.
- [tr]M.R. Murshed and S.I. Ranganathan,
Hill-Mandel condition and bounds on lower symmetry elastic crystals, Mechanics Research Communications [tr], vol. 81, pp. 7-10, 2017.
Scaling laws in elastic polycrystals with individual grains belonging to any crystal class, Acta Mechanica [tr], doi:10.1007/s00707-016-1774-3.
- [tr]C.H. Pham, S. Thuillier and P.-Y. Manach,
Prediction of flow stress and surface roughness of stainless steel sheets considering an inhomogeneous microstructure, Materials Science & Engineering A [tr], vol. 678, pp. 377-388, 2017.
20162015
- [tr]S.L. Wong, M. Obstalecki, M.P. Miller and P.R. Dawson,
Stress and deformation heterogeneity in individual grains within polycrystals subjected to fully reversed cyclic loading, Journal of the Mechanics and Physics of Solids [tr], vol. 79, pp. 157-185, 2015.
- [tr]Lhoutellier, D. Ledue, R. Patte, F. Barbe, B. Dierny and V. Baltz,
Bimodal distribution of blocking temperature for exchange-bias ferromagnetic/antiferromagnetic bilayers: a granular Monte Carlo study with less stable magnetic regions spread over the interface, Journal of Physics D: Applied Physics, 2015.
- [tr]L.-T. Li, Y.C. Lin, L. Li, L.-M. Shen and D.-X. Wen,
Three-Dimensional Crystal Plasticity Finite Element Simulation of Hot Compressive Deformation Behaviors of 7075 Al Alloy, Journal of Materials Engineering and Performance [tr], vol. 24, pp. 1294-1304, 2015.
2014- [tr]M.P. Miller and P.R. Dawson,
Understanding local deformation in metallic polycrystals using high energy X-rays and finite elements, Current Opinion in Solid State and Materials Science [tr], vol. 18, pp. 286-299, 2014.
- [tr]D.L. Cortie, A.G. Biternas, R.W. Chantrell, X.L. Wang and F. Klose,
Microscopic model for exchange bias from grain-boundary disorder in a ferromagnet/antiferromagnet thin film with a nanocrystalline microstructure, Applied Physics Letters [tr], vol. 105, 032402, 2014.
- [tr]Zang, B. Holmedal, O.S. Hopperstad, S. Dumoulin, J. Gawad, A. Van Bael and P. Van Houtte,
Multi-level Modelling of Mechanical Anisotropy of Commercial Pure Aluminium Plate: Crystal Plasticity Models, Advanced Yield Functions and Parameter Identification, International Journal of Plasticity [tr], vol. 66, pp. 3-30, 2015.
201320122011200920082007下载:
[tr]Downloads[tr]Neper is distributed as a free / open-source software, under the terms of the GNU General Public License (GPL) [tr]. In short, this means that everyone is free to use Neper and to redistribute it on a free basis. Neper is not in the public domain; it is copyrighted and there are restrictions on its distribution (see the license [tr] and the related FAQ). [tr]It you use Neper, please cite the Neper reference paper in your work (books, papers, talks, ...): R. Quey, P.R. Dawson and F. Barbe, Large-scale 3D random polycrystals for the finite element method: Generation, meshing and remeshing, Computer Methods in Applied Mechanics and Engineering, vol. 200, pp. 1729-1745, 2011. The paper is available for download below. [tr]Current stable release[tr]Development repository[tr]A development repository is hosted on GitHub: http://github.com/rquey/neper [tr]. It provides the development version. Code contributions to be included in the official (public) version of Neper should be submitted as pull requests. [tr]Supplementary software[tr]References- [tr]Romain Quey, Paul Dawson and Fabrice Barbe, Large-scale 3D random polycrystals for the finite element method: Generation, meshing and remeshing, Comput. Methods Appl. Mech. Engrg., vol. 200, pp. 1729-1745, 2011:
paper - [tr]Romain Quey and Loïc Renversade, Optimal polyhedral description of 3D polycrystals: Method and application to statistical and synchrotron X-ray diffraction data, Comput. Methods Appl. Mech. Engrg., vol. 330, pp. 308-333, 2018:
postprint link - [tr]Romain Quey, Aurelien Villani and Claire Maurice, Nearly uniform sampling of crystal orientations. J. Appl. Crystallogr., vol. 51, pp. 1162-1173, 2018.
reprint link
[tr]Mailing lists[tr]There are two mailing lists for Neper, which you may find useful to subscribe to: neper-announce [tr]: the “read-only” list for important news: new releases, bug fixes, etc. (low traffic, highly recommended!).neper-users [tr]: the “read-write” list for users. Please send all questions, bug reports, requests or any errors or omissions in this manual to this list.
ABAQUS断裂模拟收徒 ,保证快速学会各种ABAQUS断裂模拟方法 1200/人(将享有各种插件以及程序,价值3000+、专门定制视频、全程亲自教学、各种模型调试及解答问题等等,倾囊相教) |
