___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : smp s R8.0.0 Date: 01/22/2015 |
| Revision: 95309 Time: 07:38:44 |
| Features enabled in this version: |
| Shared Memory Parallel |
| FFTW (multi-dimensional FFTW Library) |
| Interactive Graphics |
| ANSYS Database format |
| ANSYS License (ANSYS170) |
| Licensed to: |
| Issued by : ANSYS |
| Platform : WINDOWS X64 |
| OS Level : SP1 B7601ista/7/8 Server 2008/2012|
| Compiler : Intel Fortran XE 2013 MSVC++ 2010 |
| Hostname : PC-20170908SACD |
| Precision : Single precision (I4R4) |
| SVN Version: 95245 |
| Unauthorized use infringes LSTC copyrights |
Input file: juxingwuzhihu4.k
The native file format : 32-bit small endian
Memory size from command line: 400000000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2015 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
Beginning of keyword reader 11/15/18 18:21:52
expanding memory to 400000000 beginning of keyword reader
contracting memory to 22506
expanding memory to 5772778
expanding memory to 21135526
expanding memory to 21165526
expanding memory to 21225526
expanding memory to 21246862
expanding memory to 24667006
expanding memory to 28074950
expanding memory to 28095950
expanding memory to 28117870
expanding memory to 28145406
expanding memory to 29104388
expanding memory to 30059948
expanding memory to 40571108
expanding memory to 41526668
expanding memory to 56844416
expanding memory to 57799976
expanding memory to 57821976
expanding memory to 57856858
Memory required to process keyword : 57856858
contracting memory to 1 end of keyword reader
LS-DYNA will perform a structural only analysis
LS-DYNA user input
ls-dyna smp.95309 s date 01/22/2015
initializing stresses from file: drelax
expanding memory to 3297 material, node and element data
expanding memory to 3419 material added airbag porosity leakage
contracting memory to 3419 material properties
expanding memory to 10319838 element data for composite material
expanding memory to 12238084 gradient of damage data
expanding memory to 25003001 user control for contact interfaces
expanding memory to 25958541 temp index array for node sorting
contracting memory to 25002981 for boundary cond. vectorization
expanding memory to 25853967 arbitrary element numbering input
contracting memory to 25002981 thick shell int. pt. strain
expanding memory to 25050401 spc cards
expanding memory to 25901368 MAT_ADD_EROSION for solid elements
expanding memory to 60372187 process element material data
expanding memory to 60374188 load curve data
contracting memory to 60372194 user_define_loading_set
expanding memory to 60372394 regularize time history data
expanding memory to 60372398 *DEFINE_ELEMENT_DEATH
contracting memory to 60372398 rigidwall definitions
expanding memory to 61365516 nodal constraint sets
expanding memory to 67291353 contact interfaces
expanding memory to 76861347 mass scaling with ale
expanding memory to 79728027 ALE neighboring info
expanding memory to 195308212 ALE MMG storage 1
expanding memory to 215273519 ALE MMG storage 2
expanding memory to 233738587 ALE MMG storage 3
expanding memory to 241397465 ALE multimaterial storage
expanding memory to 241398465 contact segment data 1
expanding memory to 251073033 contact segment data 3
contracting memory to 242353025 contact definition
expanding memory to 246175708 rigid body
contracting memory to 242353894 contact friction
expanding memory to 242353954 joints
contracting memory to 242353954 accelerometers
expanding memory to 242449282 non-reflecting silent boundary 1
expanding memory to 242449382 rigid bodies for disp. termination
contracting memory to 242449382 transformation to move nodes
expanding memory to 246901794 ale reference system
expanding memory to 246901941 ALE fsi control block
expanding memory to 246901945 ALE fsi node and seg list
expanding memory to 247999265 ALE fsi seg connectivity
expanding memory to 284274631 ALE fsi coupling forces
expanding memory to 288096951 void materials
expanding memory to 290008071 interfac for file
contracting memory to 289052515 thermal expansion 0
expanding memory to 289052519 mat add cohesive 0
contracting memory to 289052519 sensor_control for curve
expanding memory to 289052523 flexible body 2
contracting memory to 289052523 implicit joints
expanding memory to 292456467 initialization phase
