- 2018-11-14
*** WARNING # 1848
Topology optimization without minimum member size control activated.
Using DTPL card or DOPTPRM,MINDIM is recommended.
*** INFORMATION # 815
The total number of rigid elements, whose rotational dependent d.o.f.
are removed because there is no need to constrain those d.o.f., is 63.
NOTE # 1852
AUTOMATIC SCREENING is activated.
Use DSCREEN,AUTO,OFF to disable automatic screening.
*** ERROR # 173 ***
A dependent d.o.f. defined more than once in rigid element entry.
GRID ID = 876
component = 1
*** ERROR # 173 ***
GRID ID = 876
component = 2
*** ERROR # 173 ***
GRID ID = 876
component = 3
*** ERROR # 173 ***
GRID ID = 2441
component = 1
*** ERROR # 173 ***
GRID ID = 2441
component = 2
*** ERROR # 173 ***
GRID ID = 2441
component = 3 |
