command: !
command: !INFO Adams Version: Adams 2016
command: !INFO Adams Build: 2016.0.0-CL426750
command: !INFO Assembly File:
command: !INFO Solver Library: D:/ProgramFiles/admas/win64/acar_solver.dll
command: !
command: preferences/solver=CXX
command: preferences/list,status=on
PREFERENCES:
SIMFAIL = NOSTOPCF
Contact Geometry Library = (not loaded)
Thread Count = 1
Library Search Path = Not Set
Status Message = On
Solverbias = CXX (C++ Solver)
command: control/ routine=acarSDM::con950, function=user(950,29,31,1,2,18,20,1,3,2,3,28,30,2,3,28,30,1,1,0,0,0)
Begin Static Solution
STATICS: Original static solver will be used with the Sparse linear solver.
Static Solution converged in 7 iterations
Residual imbalance is less than 1.74510E-10
End Static Solution
Begin Simulation
****** Performing Quasi-Static Simulation ******
Simulation Step Function Cumulative CPU Slvr
Time Size Evaluations Steps Taken time type
___________ ___________ ___________ ___________ ________ ___
0.00000E+00 0.00000E+00 0 0 0.28 1
1.00000E-01 1.95582E-03 16267 50 24.78 1
End Simulation
Begin Simulation
Time: 1.849504402E-01.
QSTATIC: Step Size Too Small: 7.348417850E-06
End Simulation
Simulation failed
Begin Simulation
1.84950E-01 7.34842E-06 51400 127 24.78 1
3.00000E-01 1.15050E-01 51426 128 1:17 1
End Simulation
Begin Simulation
4.00000E-01 9.37500E-03 51734 133 1:17 1
End Simulation
Begin Simulation
5.00000E-01 8.71511E-03 68153 165 1:42 1
End Simulation
Begin Simulation
Time: 5.290093912E-01.
QSTATIC: Step Size Too Small: 8.665845798E-06
End Simulation
Simulation failed
Begin Simulation
5.29009E-01 8.66585E-06 94840 204 1:42 1
QSTATIC: Step Size Too Small: 1.043643852E-05
End Simulation
Simulation failed
Begin Simulation
5.29009E-01 1.04364E-05 96010 204 1:42 1
QSTATIC: Step Size Too Small: 1.653995415E-05
End Simulation
Simulation failed
Begin Simulation
5.29009E-01 1.65400E-05 97192 204 1:42 1
QSTATIC: Step Size Too Small: 2.264346977E-05
End Simulation
Simulation failed
Begin Simulation
5.29009E-01 2.26435E-05 98375 204 1:42 1
QSTATIC: Step Size Too Small: 2.874698540E-05
End Simulation
Simulation failed
Static Solution converged in 1 iterations
Residual imbalance is less than 2.21849E-08
End Static Solution
command: simulate/static, end=101.000000, steps=100
Begin Simulation
5.29009E-01 0.00000E+00 0 0 2:28
QSTATIC: Step Size Too Small: 6.132262610E-05
End Simulation
Simulate status=-124
command: !
command: stop
Termination status=0
Terminating Adams Car usersubs...
Finished -----
Elapsed time = 150.94s, CPU time = 150.14s, 99.47%
Loading analysis results...
Loading results done.
