- 2017-10-31
救急:出现警告For *tie pair (assembly_s_surf-29-assembly_m_surf-29), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_s_surf-31-assembly_m_surf-31), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_s_surf-35-assembly_m_surf-35), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly_s_surf-37-assembly_m_surf-37), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
12 nodes are used more than once as a slave node in *TIE keyword. One of the *TIE constraints at each of these nodes have been removed. The nodes have been identified in node set WarnNodeOverconTieSlave.
16752 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
16 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncorrectDof.
求问大神,该如何解决啊?
