- 2017-9-17
楼主 |
发表于 2018-12-26 20:53:42
来自 山西太原
std_user.log for 的内容为:
Processing time = 0 second(s).
Abaqus JOB std_user
Abaqus 6.12-1
DriverLM command: D:\SIMULIA\6.12-1\code\bin\eliT_DriverLM.exe -job std_user -indir D:\ABQUS\verify -standard -verbose -tmpdir D:\ABQUS\tianye_std_user_6444 -lmlog
Checkout succeeded: standard/F7D48D30A192
License file: 27000@chengbin-PC
License Server: 27000@chengbin-PC
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens.
<1019 out of 1024 licenses remain available>.
DriverLM status: 0
Umbrella port: chengbin-PC 12829
Platform: win86_32
FORTRAN extension: for
Object extension: obj
Shared library name: standardU.dll
User subroutine archive file: standardU_static.lib
Utility shared library file: standardB
Begin Compiling Abaqus/Standard User Subroutines
12/26/2018 8:01:12 PM
Compiling std_user.for
Compile command: ['ifort', '/c', '/iface:nomixed_str_len_arg', '/iface:cref', '/recursive', '/nologo', '/heap-arrays:1', '/include:\\ABQUS\\verify', '/Od', 'Zi', 'std_user.for']
Current directory: D:\ABQUS\tianye_std_user_6444
File to compile (full path): D:\ABQUS\tianye_std_user_6444\std_user.for
ifort: command line warning #10161: unrecognized source type 'Zi'; object file assumed
Checkout succeeded: FCompW/A8648F8CF49E
License file: C:\Program Files\Common Files\Intel\Licenses\Intel Visual Fortran Composer XE 2013.lic
No server used
ifort: warning #10146: no action performed for specified object file(s)
End Compiling Abaqus/Standard User Subroutines
Begin Linking Abaqus/Standard User Subroutines
export.sym: contactperm
export.sym: creep
export.sym: dflow
export.sym: dflux
export.sym: disp
export.sym: dload
export.sym: film
export.sym: flow
export.sym: fric
export.sym: fric_coef
export.sym: gapcon
export.sym: gapelectr
export.sym: hardini
export.sym: hetval
export.sym: mpc
export.sym: orient
export.sym: rsurfu
export.sym: sdvini
export.sym: sigini
export.sym: uamp
export.sym: uanisohyper_inv
export.sym: uanisohyper_strain
export.sym: ucorr
export.sym: ucosimulation
export.sym: ucrack
export.sym: ucreepnetwork
export.sym: udecurrent
export.sym: udempotential
export.sym: udmgini
export.sym: udsecurrent
export.sym: uel
export.sym: uelmat
export.sym: uexpan
export.sym: uexternaldb
export.sym: ufield
export.sym: ufluid
export.sym: ufluidleakoff
export.sym: ugens
export.sym: uhard
export.sym: uhypel
export.sym: uhyper
export.sym: uinter
export.sym: umasfl
export.sym: umat
export.sym: umat_sst
export.sym: umatht
export.sym: umeshmotion
export.sym: umotion
export.sym: umullins
export.sym: uporep
export.sym: upress
export.sym: upsd
export.sym: urdfil
export.sym: usdfld
export.sym: utemp
export.sym: utracload
export.sym: utrs
export.sym: uvarm
export.sym: uwave
export.sym: voidri
export.sym: ?SMAStsStdU_initialize@@YAXAAH@Z
export.sym: ?SMAStsStdU_finalize@@YAXAAH@Z
export.sym: ?SMAStsUsubs_specific_initialize@@YAXAAH@Z
export.sym: ?SMAStsUsubs_specific_finalize@@YAXAAH@Z
export.sym: ?SMAStsUsubs_initialize@@YAXAAH@Z
export.sym: ?SMAStsUsubs_finalize@@YAXAAH@Z
export.sym: stdu_callallutils
export.sym: _forceCRTManifestCUR
Linking ['std_user.obj'] into user subroutine shared library
Link command: ['LINK', 'DEBUG', '/nologo', '/INCREMENTAL:NO', '/subsystem:console', '/machine:X86', '/NODEFAULTLIBIBC.LIB', '/NODEFAULTLIB:LIBCMT.LIB', '/DEFAULTLIB:OLDNAMES.LIB', '/DEFAULTLIB:LIBIFCOREMD.LIB', '/DEFAULTLIB:LIBIFPORTMD.LIB', '/DEFAULTLIB:LIBMMD.LIB', '/DEFAULTLIB:MSVCRT.LIB', '/DEFAULTLIB:kernel32.lib', '/DEFAULTLIB:user32.lib', '/DEFAULTLIB:advapi32.lib', '/FIXED:NO', '/dll', '/def:export.def', '/out:standardU.dll', 'std_user.obj', 'D:\\SIMULIA\\6.12-1\\code\\lib\\standardU_static.lib', '/LIBPATH:D:\\SIMULIA\\6.12-1\\code\\lib', '/LIBPATH:D:\\SIMULIA\\6.12-1\\code\\bin\\SMAExternal', 'standardB.lib', 'ABQSMABasCoreUtils.lib', 'ABQSMAAbuLicense.lib']
LINK : fatal error LNK1181: cannot open input file 'DEBUG.obj'
Abaqus Error: Problem during linking - Abaqus/Standard User Subroutines.
This error may be due to a mismatch in the Abaqus user subroutine arguments.
These arguments sometimes change from release to release, so user subroutines
used with a previous release of Abaqus may need to be adjusted.
Exception: (<class 'driverExceptions.LinkError'>, LinkError('Abaqus/Standard User Subroutines',), <traceback object at 0x7F5D92D8>)
Traceback (most recent call last):
File "SMAPyaModules\SMAPyaDriverPy.m\src\driverAnalysis.py", line 177, in run
File "SMAPyaModules\SMAPyaDriverPy.m\src\driverStandard.py", line 65, in analyze
File "SMAPyaModules\SMAPyaDriverPy.m\src\driverSharedLibrary.py", line 210, in run
File "SMAPyaModules\SMAPyaDriverPy.m\src\driverSharedLibrary.py", line 356, in link
LinkError: Abaqus/Standard User Subroutines
Abaqus/Analysis exited with errors |
