- 2018-11-9
ERROR in job messaging system: Error in connection to analysis
Application restarted after 787 minutes of idle time; the license will be checked within the next 3 minutes.
Error in job smooth_zero25_20181226-2: The executable standard.exe aborted with system error code 1073740791. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
请问各位大佬这个问题怎么解决? |
