Error in job Job-1: in keyword *BOUNDARY, file "Job-1.inp", line 4319: Unknown assembly node set SET-1
Error in job Job-1: The surface ASSEMBLY__INT-1_GCS0_28 has not been defined.
Error in job Job-1: The surface ASSEMBLY__INT-1_GCS0_30 has not been defined.
Error in job Job-1: The surface ASSEMBLY__INT-1_GCS0_32 has not been defined.
Error in job Job-1: The surface ASSEMBLY__INT-1_GCS0_34 has not been defined.
Error in job Job-1: The surface ASSEMBLY__INT-1_GCS0_36 has not been defined.
Error in job Job-1: SURFACE DEFINITION ASSEMBLY_SURF-1 NOT FOUND.
Error in job Job-1: NODE SET ASSEMBLY_SET-1 HAS NOT BEEN DEFINED
Error in job Job-1: Analysis Input File Processor exited with an error.
Job Job-1 aborted due to errors.
