查看: 283|回复: 2
[错误和警告信息] 关于LS-DYNA炸药冲击起爆仿真出错
发表于 2019-3-4 22:50:44 | 显示全部楼层 |阅读模式 来自 四川绵阳
   我最近正在做LS-DYNA做飞片冲击起爆炸药仿真,其中飞片选用JOHNSON_COOK材料模型和GRUNEISEN状态方程,被发炸药选用ELASTIC_PLASTIC_HYDRO材料模型和IGNITION_AND_GROWTH_OF_REACTION_IN_HE状态方程。但是在仿真时候总是出现这样的错误:
S t o r a g e   a l l o c a t i o n
Memory required to begin solution      :     1879064
Additional dynamically allocated memory:     1163915
                                   Total:     3042979
*** Error 40510 (SOL+510)
     complex sound speed in solid element # 65 cycle 0
*** Warning 40510 (SOL+510)
     complex sound speed in solid element # 66 cycle 0
     complex sound speed in solid element # 67 cycle 0
     complex sound speed in solid element # 68 cycle 0
     complex sound speed in solid element # 69 cycle 0
     complex sound speed in solid element # 70 cycle 0
     complex sound speed in solid element # 71 cycle 0
     complex sound speed in solid element # 72 cycle 0
     complex sound speed in solid element # 73 cycle 0
     complex sound speed in solid element # 74 cycle 0
     complex sound speed in solid element # 75 cycle 0
     complex sound speed in solid element # 76 cycle 0
     complex sound speed in solid element # 77 cycle 0
     complex sound speed in solid element # 78 cycle 0
     complex sound speed in solid element # 79 cycle 0
     complex sound speed in solid element # 80 cycle 0
     complex sound speed in solid element # 81 cycle 0
     complex sound speed in solid element # 82 cycle 0
     complex sound speed in solid element # 83 cycle 0
     complex sound speed in solid element # 84 cycle 0
     complex sound speed in solid element # 85 cycle 0
     complex sound speed in solid element # 86 cycle 0
     complex sound speed in solid element # 87 cycle 0
     complex sound speed in solid element # 88 cycle 0
     complex sound speed in solid element # 89 cycle 0
     complex sound speed in solid element # 90 cycle 0
     complex sound speed in solid element # 91 cycle 0
     complex sound speed in solid element # 92 cycle 0
     complex sound speed in solid element # 93 cycle 0
     complex sound speed in solid element # 94 cycle 0
     complex sound speed in solid element # 95 cycle 0
     complex sound speed in solid element # 96 cycle 0
     complex sound speed in solid element # 97 cycle 0
     complex sound speed in solid element # 98 cycle 0
     complex sound speed in solid element # 99 cycle 0
     complex sound speed in solid element # 100 cycle 0
     complex sound speed in solid element # 101 cycle 0
     complex sound speed in solid element # 102 cycle 0
     complex sound speed in solid element # 103 cycle 0
     complex sound speed in solid element # 104 cycle 0
     complex sound speed in solid element # 105 cycle 0
     complex sound speed in solid element # 106 cycle 0
     complex sound speed in solid element # 107 cycle 0
     complex sound speed in solid element # 108 cycle 0
我不明白出现这种现象的原因是什么,希望有经验的大神能够解答一下。模型参数已经反复检查过,确定无误。
发表于 2019-4-17 16:48:39 | 显示全部楼层 来自 北京
出现负体积了,看看网格出现什么毛病了,或者炸药的本构不会的,或者是模型的单位不匹配
发表于 2019-4-23 10:12:22 | 显示全部楼层 来自 江苏
考虑一下参数设错了,
GMT+8, 2024-4-16 12:51 , Processed in 0.033370 second(s), 12 queries , Gzip On, MemCache On.
