- 34
- 2002-9-6
发表于 2002-9-14 10:46:20
来自 吉林吉林
回复: 【求助】我在LABVIEW下有PCI7484?
linsensor wrote:
还有就是LABVIEW调用的DLL必须包括头文件“EXTCODE.H”吗?那LABVIEW怎么调用API函数的?
extcode.h含有 LabVIEW函数的原型
请参考:
extcode.h is automatically included, because it defines basic data types and a number of routines that can be used by CINs. extcode.h also defines some constants and types whose definitions may conflict with the definitions of system header files. The cintools directory also contains hosttype.h, which resolves these differences. This header file also includes many of the common header files for a given platform.
Always use #include "extcode.h" at the beginning of your source code. If your code needs to make system calls, also use #include "hosttype.h" immediately after #include "extcode.h", and then include your system header files. hosttype.h includes only a subset of the .h files for a given operating system. If the .h file you need is not included by hosttype.h, you can include it in the .c file for your CIN after you include hosttype.h.
另:
When you build more complex shared libraries, you must include header files for all related libraries. For example, a Windows shared library project might need to include windows.h. In another instance, a project might need to include extcode.h, the header file for the set of LabVIEW manager functions that perform simple and complex operations, ranging from low-level byte manipulation to routines for sorting data and managing memory.
When you want to use the LabVIEW manager functions inside your shared
library, you must include the LabVIEW library files in your compiled
project: labview.lib forVisual C++, labview.sym.lib for Symantec, and labview.export.stub for Metrowerks CodeWarrior. These files appear in the cintools directory of your LabVIEW installation. Specifically, you need the LabVIEW manager functions if you intend to do any of the following:
• Allocate, free, or resize arrays, strings, or other data structures that are passed into or out of your library from LabVIEW.
• Work with LabVIEW Path data types.
• Work with file refnums inside your library.
• Use any of the Support Manager functions. |
