本人用patran建模,希望直接输出inp文件进入abquas进行求解。但是patran报有如下警告:$# The PCL library file, abaqus.plb, associated with the current analysis preference, ABAQUS, does not exist. This file is required and used to store analysis code specific PCL functions. This could be an installation issue. You must select a valid preference from the Preferences menu before you can continue.(与当前分析首选项abaqus关联的pcl库文件abaqus.plb不存在。此文件是必需的,用于存储特定于分析代码的PCL函数。这可能是安装问题。必须先从“首选项”菜单中选择有效的首选项,然后才能继续。)请问有没有采用此方法进行分析的大神,求解答。
