使用surf151表面效应单元,含有外部附加节点,在模拟感应加热求解计算时提示单元质量错误,很疑惑,为什么会出现这样的错误提示呢?(单元质量不合格),命令流如下:思考了3天,始终没有找到表面效应单元质量不合格原因,希望大家指点迷津,谢谢!
!------------感应线圈截面参数20×20mm-10×10mm /filenam, induc /prep7 !shpp,off /title, induction heating of a solid cylinder billet /com, et,1,13,,,1 ! PLANE13, axisymmetric, AZ dof et,2,13,,,1 et,3,151,,,1,1,1 ! SURF151, thermal, radiation r,3,0 row_in=0.0065 ! inner radius of copper conductor row_out=0.014 ! out radius of copper conductor sleeve_out=0.015 ! out radius of sleeve ric=0.019 ! inner radius of induction coil roc=0.039 ! outer radius of induction coil ro=0.125 d_coil=0.014 h_coil=0.02 t=0.08 h_sleeve=0.01 freq=1500 ! frequency (Hz.) pi=4*atan(1) ! pi cond=5.71e7 muzero=4e-7*pi ! free-space permeability murx=1 skind=sqrt(1/(pi*freq*cond*muzero*murx)) ! skin depth ftime=4 ! final time tinc=2 ! time increment for harmonic analysis time=0 ! initialize time delt=0.05 ! maximum delta time step emunit,mks ! set magnetic units mp,murx,1,1 ! air relative permeability mp,murx,3,1 ! coil relative permeability mp,murx,2,1 !copper relative permeability mptemp,1,20,100,200,250,500,600 ! temps for resistivity mptemp,7,750,900,1000 mpdata,rsvx,2,1,1.78e-8,2.33e-8,2.92e-8,3.35e-8,5.386e-8,6.25e-8 mpdata,rsvx,2,7,7.41e-8,8.75e-8,9.72e-8 ! copper resistivity rectng,0,row_in,0,t/2 rectng,row_in,row_out,0,t/2 ! 铜管 rectng,row_out, ric,0,t/2 !线圈和铜管之间的空气场 rectng,ric,roc,d_coil/2,d_coil/2+h_coil ! 实心线圈截面 rectng,ric+h_coil/4,roc-h_coil/4,d_coil/2+h_coil/4,d_coil/2+0.75*h_coil !线圈中的空心截面 rectng,0,ro,0,t/2 ! outer air
alls aptn,all !面布尔运算 alls arsym,y,all,,,,0,0 !创建对称面 nummrg,kp numcmp,kp lsel,s,length,,row_out-row_in asll,s aatt,2,1,1 !为铜管分配材料编号2,实常数集1和单元类型1 cm,copper,area lsel,s,length,,0.5*h_coil asll,s,1 cm,air_1,area lsel,s,length,,h_coil lsel,a,length,,0.5*h_coil asll,s,1 asel,u,,,air_1 aatt,3,1,2 cm,coil,area alls asel,u,,,copper asel,u,,,coil aatt,1,1,2 cm,air,area !创建空气面组件 alls lesize,all,0.001 mshape,0,2d amesh,copper amesh,coil amesh,air nummrg,node numcmp,node n !为surf151创建空间节点
*get,nmax,node,,num,max type,3 !激活第三种单元类型 real,3 !实常数集编号为3 mat,2 ksel,s,loc,x,row_out lslk,s,1 lmesh,all esll,s emodif,all,3,nmax
et,3,0 ! reset type 3 to null element alls /solu nsel,s,loc,x nsel,u,,,nmax d,all,az,0 ! apply flux-normal b.c. alls esel,s,mat,,3 bfe,all,js,,,,33.3e6 ! apply current density to coil alls antyp,harm harfrq, freq !感应加热的频率 physics,write,emag ! write emag physics file finish
/prep7 lsclear,all ! clear all b.c.'s and options et,1,55,,,1 ! PLANE55 thermal element, axisymmetric et,2,0 ! null element type for coil and air region et,3,151,,,1,1,1 ! SURF151 element for radiation keyopt,3,9,1 r,3,1,5.67e-8 ! form factor, Stefan-Boltzmann constant mp,dens,2,8.9e3 mptemp mptemp,1,0,20,100,300,400,600 mptemp,7,800,1000,1100 mpdata,kxx,2,1,401,398,393,384,379,366 mpdata,kxx,2,7,352,336,170 mptemp mptemp,1,0,20,100,200,600,1000 mptemp,7,1100 mpdata,c,2,1,0.34e3,0.38e3,0.39e3,0.4e3,0.44e3,0.48e3 mpdata,c,2,7,0.5e3 mp,emis,2,.60 finish /solu alls antype,trans toffst,273 tunif,25 ! initial uniform temperature d,nmax,temp,25 ! ambient temperature cnvtol,heat,1 ! convergence tolerance kbc,1 ! step loads trnopt,full autots,on ! auto time-stepping deltim,1e-3,1e-4,delt,on ! time step control outres,all,all ! save all load step information physics,write,thermal ! write thermal physics file finish alls *do,i,1,ftime/tinc ! solution *do loop time=time+tinc ! increment time physics,read,emag ! read emag physics file /solu *if,i,eq,1,then tunif,25 ! initial temperature *else ldread,temp,last,,,,,rth ! read thermal analysis temperatures *endif solve ! solve harmonic analysis finish !------------------------------------------ physics,read,thermal ! read thermal physics file /assign,esav,therm,esav ! redirect files for use in thermal restart /assign,emat,therm,emat /solu parsav,scalar,parameter,sav !save parameters before multiframe restart *if,i,gt,1,then antype,trans,rest ! thermal restart *endif parres,new,parameter,sav !restore parameters after multiframe restart time,time ! time at end of thermal run esel,s,mat,,2 ! select billet region ldread,hgen,,,,2,,rmg !apply coupled joule heating load from emag esel,all solve finish /assign,esav ! reassign files to default /assign,emat *enddo ! end of solution looping finish save ! save database /post26 ! time-history postprocessor /show nsol,2,1,temp,,tempcl ! store temperature at billet centerline nsol,3,2,temp,,tempsurf !store temperature at billet outer diameter plvar,2,3 ! plot temperature rise over time prvar,2,3
