- 2019-6-29
The parameter hourglass on the *section controls option is relevant for solid, membrane, and shell elements with reduced integration wherever applicable. This warning can be ignored if the feature is applied to these element types only.
For two-dimensional models, if a non-unity thickness is specified for two-dimensional solid elements and these elements are involved in an interaction such as contact, the same thickness should be specified for the out-of-plane thickness of the corresponding surface under *surface interaction.
Output request evf is not available for element type c3d8r
Output request peeqvavg is not available for element type c3d8r
Output request pevavg is not available for element type c3d8r
Output request svavg is not available for element type c3d8r
Output request damagec is not available for the material for element type c3d8r
Output request damaget is not available for the material for element type c3d8r
Output request sdeg is not available for the material for element type c3d8r
Output request damagec is not available for the material for element type t3d2
Output request damaget is not available for the material for element type t3d2
Output request evf is not available for element type t3d2
Output request peeqvavg is not available for element type t3d2
Output request pevavg is not available for element type t3d2
Output request sdeg is not available for the material for element type t3d2
Output request svavg is not available for element type t3d2
The option *boundary,type=displacement has been used; check status file between steps for warnings on any jumps prescribed across the steps in displacement values of translational dof. For rotational dof make sure that there are no such jumps. All jumps in displacements across steps are ignored
There are 35 warning messages in the data (.dat) file. Please check the data file for possible errors in the input file. |
