- 2019-7-13
Digital printing definition
(1) Digital printing is a printing technique that uses digital or electronic files from a personal computer or other digital storage device as a source. Digital printing does not rely on the platen to transfer images, nor does it require any setup pages. Due to lower production costs, digital printing has replaced lithography in a wide range of markets.
(2) Modern printing methods such as laser and inkjet printing are called digital printing. Digital printing includes images that are sent directly to the printer using digital files such as PDF and graphics software such as Illustrator and In Design. This eliminates the need for plates that are commonly used in offset printing, which saves money and time.
Digital printing
WeChat picture_20190709182214
Digital printing on MDF board details
product
Digital printing on wood laminated MDF boards
Based on the board
MDF, particleboard,
specification.
size
Digital printing on the MDF board, 1220 * 2440mm (4x8) (4x10) or according to your requirements
thickness
4 mm - 25 mm
gum
E0, E1, E2, MR
Melamine paper
Through our 24-color digital printing, any photo, fantasy pattern design, customer-provided wood grain and stone can be printed on the base paper.
material
Medium density fiberboard
moisture
Less than 8%
density
650-750 Kg / M3
Surface treatment
Smooth, matte, glossy, embossed, etc.
filler
Loosely packed or standard tray packaging according to your requirements
certificate
Crab, ISO9001, ISO14001
usage
Use for making furniture
MOQ
1 * 20'GP
payment
T / T or L / C in sight
delivery time
Within 15-20 days after receiving the deposit or original letter of credit
Melamine MDF board process digital printing machine
Digital printing utilizes raster images and sends them directly to the printer via digital file and graphics software applications. A raster image (also known as a bitmap) is an X and Y coordinate grid on the display space that contains detailed information about the coordinates to be illuminated. Unlike other printing processes, the toner does not penetrate the substrate. The toner actually forms a thin layer on the surface and can be used as a part of the heat treatment or UV curing process by adhering to the surface by the fixing solution. This results in a digitally printed surface on a wood laminated MDF board.
Digital printing VS screen printing
Digital printing has many benefits. It can provide faster turnaround times. It is better quality and lower cost than screen printing. It is a good choice for print on demand or any print that requires a shorter turnaround time. Because it is non-contact printing, it gives designers the choice of printed substrates. Unlike screen printing, image distortion does not occur in digital printing.
However, digital printing costs more per page than traditional screen printing.
Digital mdf wall panel
Digital MDF printing advantages:
(1) Shorten the turnaround time.
Every print is the same. Since there is no need to balance ink and water during the printing process, the counting is more accurate, less waste, and less variable.
(2) Cheap small batch printing.
While the unit cost per piece may be higher than offset printing, digital printing offers lower unit costs in very small printing runs when setting costs.
(3) High image quality.
Suitable for a variety of printing surfaces, including paper, wood, fabric, metal, leather, rough paper and plastic.
(4) Quantity advantage.
Offset printing has a front end cost load. Short-term operations can result in high unit costs. But as the quantity increases, the unit cost decreases with offset printing. With digital printing, very short runs can be more cost effective; although larger quantities can reduce unit cost through offset printing.
(5) Print materials.
Digital printing can meet special paper, surface finishes or unusual printed surfaces or unique sizes. However, this aspect of instructional printing is limited.
(6) Color.
The digital press uses four-color printing. If you only need black ink or one or two ink colors, offset printing may provide a more cost effective solution. If you need four-color printing, these numbers offer a lower upfront cost advantage.
(7) Proofing.
Digital provides accurate proofs because you can see the actual samples printed. Accurate color proofing of offset printing can be expensive.
(8) Customization.
There is no doubt that digital printing offers the most affordable way to customize marketing materials, direct mail, letters and more.
Digital printing MDF board application:
We develop custom printed melamine panels by thermally bonding the impregnated paper to a substrate (usually MDF and particleboard) under high pressure. The flat, impact-resistant and sturdy internal structure make it the most commonly used cost-effective building board. It has a wide range of applications from kitchen to office furniture:
(1) Table
(2) wall
(3) door
(4) Toilet cubicle
(5) logo
Digital principle
https://www.yspanel.com/digital- ... ated-mdf-board.html |
