- 2018-9-5
悬赏5仿真币未解决
我一个模型是15*10*10的长方体,有1500个单元。有没有大神能写一个代码来遍历这个长方体内所有的n*n*n的小正方体(从1*1*1到10*10*10)比如1*1*1的有1500,2*2*2的有1134个,3*3*3的有832个,然后输出每个正方体区域的平均应力应变(Stress average = Sum (Stress (element)*volume (element))/Sum (volume (element)))。
例如一个2*2*2的正方体, 拿由单元编号1,2,11,12,101,102,111,112组成的2*2*2的来说,我要得到这八个单元的应力,分别乘以他们的单元体积,然后除以他们的总体积.
有一份参考代码
import sys, getopt, os, string
import math
from odbAccess import *
from abaqusConstants import *
odbPath = "D:\ho\Desktop\Abaqus Script\M1.odb"
odb = session.openOdb(name=odbPath,readOnly=FALSE)
# retrieve steps from the odb
grout_instance = odb.rootAssembly.instances['COULIS_SMOOTH-1']
numElem = len(grout_instance.elements)
keys = odb.steps.keys()
for stp in keys:
step = odb.steps[stp]
# retrieve frames from the odb
frameRepository = step.frames
numFrames = len(frameRepository)
for fr in range(0,numFrames):
frame=step.frames[fr]
print 'Id = %d, Time = %f\n'%(frame.frameId,frame.frameValue)
# get fieldOutputs object
fo = frame.fieldOutputs
S = fo['S']
EVOL = fo['EVOL']
S_grout = S.getSubset(region=grout_instance,\
position=INTEGRATION_POINT,
elementType='CAX3')
EVOL_grout = EVOL.getSubset(region=grout_instance)
myStress_data = {} #Declaration of my New stress Data
# Loops over elements to get stpress S11 and Volume
for i in range(0,len(S_grout.values)):
evol= EVOL_grout.values.data
a = (S_grout.values.data[0])*evol
elemId=S_grout.values.elementLabel
myStress_data.setdefault(elemId,[]).append(a)
# Append
elementLabels = []
elementData = []
for key in sorted(myStress_data.iterkeys()):
elementLabels.append(key)
elementData.append(myStress_data[key])
myS11 = frame.FieldOutput(name='myS11',
description='my Principle stpress S11',
type=SCALAR)
myS11.addData(position=INTEGRATION_POINT,
instance=grout_instance,
labels=elementLabels,
data=elementData)
odb.save()
odb.close()
附件: 您需要 登录 才可以下载或查看,没有账号?注册
