- 2019-7-13
1. Solid wood
Solid wood is environmentally friendly, good in texture, resistant to high temperature and scratches, but expensive and troublesome to maintain. It is not suitable for dry and humid places. Therefore, the kitchen should be dried as soon as possible after the operation to avoid deformation due to long-term immersion.
2, refractory plate
The fireproof plate has the characteristics of abrasion resistance, scratch resistance, high-temperature resistance and the like, and has the defects of easy moisture corrosion, degumming deformation and the like caused by improper use.
3. melamine board
The melamine board is also a common cabinet material. It has the properties of friction resistance, impact resistance, high-temperature resistance, acid resistance, and alkali resistance. Water-resistance is poor, but it is also very good. The performance of the melamine board is not bad.
Use of high-gloss cabinet products:
Widely used in furniture products, cabinet products, wardrobe products, piano products, bathroom cabinet products, door panel products, indoor and outdoor decoration projects.
https://www.yspanel.com/info/how ... s Kitchen Cabinets?[/url] |
