查看: 165|回复: 3
电脑内存足够,网格划分不算太多,求解还老是出错
发表于 2019-7-23 10:39:16 | 显示全部楼层 |阅读模式 来自 江苏南京
电脑内存原来是8g,后来加装了8g的内存条,网格划分的数量跟加装内存条前差不多,也就15万网格,为什么求解时老是出现下面的问题,上网查了很久,都没查到原因,求大神解救,万分感谢!
问题如下:
*** WARNING ***                         CP =      55.141   TIME= 21:45:50
The Distributed Sparse Matrix Solver is currently running in the
out-of-core memory mode.  This memory mode may provide significantly
worse performance compared to the in-core memory mode, depending on
the amount of available system memory and I/O speed.  Please monitor
the solver performance to ensure that the large amount of I/O to the
solver files does not create a bottleneck for performance.
*** ERROR ***                           CP =      98.562   TIME= 21:46:41
An input/output error has occurred while trying to open a file with
length = 3 GB.  Error code = 112, which translates to: 磁盘空间不足。
The program is unable to open file file1.DSPtri.  If the suggestions in
the associated error messages immediately preceding and/or following
this error message do not help resolve the file issue, please send the
data leading to this operation to your technical support provider,
along with the I/O error code of -1 and the system error code of 0,
for help in determining the possible reasons as to why this file could
not be opened.
An input/output error has occurred on the process with MPI Rank ID = 1.
  This error occurs when trying to open a file with length = 4 GB.
Please check to make sure there is enough free disk space in the
working directory (E:\zuijin\anli\_ProjectScratch\Scr5288) on machine
(DESKTOP-J2BGQ1T).
发表于 2019-7-24 09:02:01 | 显示全部楼层 来自 上海浦东新区
  如果你的机器是 32 位的,内存大于 2G 是没有用的。
  如果你的机器是 64 位的,可以安装 64 位的软件,应该就不会出现这种问题了。
  另一个可能是后安装的 8 G 内存与以前的内存不兼容,需要请专业人员测试一下。
 楼主| 发表于 2019-7-24 10:56:44 | 显示全部楼层 来自 江苏南京
  如果你的机器是 64 位的,可以安装 64 位的软件, ...
嗯嗯,谢谢,已解决。原来是之前文件所在的磁盘空间不足,在另外一个磁盘创建文件后再运算就求解成功了,在mechanical里面求解固体结构问题太耗磁盘空间了。
发表于 2019-7-26 08:36:41 | 显示全部楼层 来自 上海浦东新区
  问题解决了就好。
GMT+8, 2024-5-20 16:27 , Processed in 0.034260 second(s), 12 queries , Gzip On, MemCache On.
