查看: 204|回复: 0
[流固耦合] 热弹流耦合错误信息The executable SMACfdMain.exe aborted with system
发表于 2019-12-8 17:58:03 | 显示全部楼层 |阅读模式 来自 福建福州
做摩擦片热固流耦合时,出现错误信息为:Co-simulation communication has ended prematurely. Please check for errors for each of the analysis involved in co-simulation.
An unrecoverable co-simulation error has been encountered.
The executable SMACfdMain.exe aborted with system error code 3. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. abaqus版本为6.14.4,模型是布尔运算切除掉的,图形装配成功和耦合面接触良好,希望大佬能帮忙解决。
GMT+8, 2024-4-19 21:22 , Processed in 0.024384 second(s), 11 queries , Gzip On, MemCache On.
