- 10
- 2002-12-1
发表于 2003-11-6 13:46:11
来自 LAN
回复: 【讨论】如何控制nastran的计算输出
Quote from Nastran Q&A, you can add following cards in your bdf file:
INIT SCRATCH LOGICAL=(SCR1( 150MB ),SCR2( 100MB )) ,
SCR300=(SCRA( 250MB ),SCRB( 300MB ))
ASSIGN SCR1=’file_name.scr1’
ASSIGN SCR2=’file_name.scr2’
ASSIGN SCRA=’file_name.scra’
ASSIGN SCRB=’/mydisk1/file_name.scrb’
Above example creates the SCRATCH DBset with logical names of SCR1, SCR2, SCRA, and SCRB (Of course, you can have more such as SCR3, etc.). Two physical files, file_name.scr1 and file_name.scr2, are created with 150 and 100 megabytes, respectively. These two files are regular scratch files and reside in the current directory.
Two additional physical files, file_name.scra and file_name.scrb, are created with 250 and 300 megabytes, respectively. These two files are SCR300-type files. The SCR300 file file_name.scra resides in the current directory. The SCR300 file file_name.scrb is allocated to the file system (directory) /mydisk1.
But, if your hard disk is too small to store all DBset. You will get failure message. |
